Gasoline Grade
Hey Todd,
1st Congrats on your purchase....I too have the 05, 3L auto and love it.
2nd.. The best fuel I found that actually saves gas is the premium fuel 91 octane or better. I've been using 93 and she just purrs like a kitten.
I think the owner???s manual also states to use 91 or better. You can by all means use the 89 but your performance and fuel economy will suffer. If you decide to use 89 you will after the second fill up notice a drastic decrease in fuel economy (due to the computer advancing the timing to max) and sluggish performance.. (Been there, done that)
Anyway, good luck..
________
Digital vaporizer
Anyway, good luck..
________
Digital vaporizer
Yeah, shes something else....love mine too....wish she had a turbo now......h,mmmmmm
________
Airsoft aeg
________
Airsoft aeg
Todd,
First, I suppose it all depends on where you live. Northwest states where you're 1K or better feet above see level or south east right at see level? At Higher altitude, lower octane will do.
Here is jersey, I used to use the 89 and the performance was horrible....then I read the owners manual, clearly states using 93 or better for my 3L. Once I started using the high octane fuel, not only did I get the performance, but fuel economy jumped as well.
The computer compensates for your low octane fuel, and remembers you have a high compression engine, 10.5:1. That is the same compression that race engines use.....but since your computer "retards" the ignition to compensate, you don't hear the pinging going on in your engine, as it starts to tear the engine apart. Keep using that fuel and you'll see a decrease in fuel economy, since the computer "retarded" your ignition, your performance level dropped considerably as well. If you're a slow driver and don't care about performance....you probably won't notice the performance loss....but I can guarantee that your fuel economy will start to decrease.
My suggestion and experience is to stick with the high octane. I don't like paying the high prices as well, but that???s what my baby needs...
________
Prilosec pregnancy
________
Prilosec pregnancy
Guest
Posts: n/a
My local dealer (Troy Michigan) informed me that they recommend 89 Octane during the winter months.
I'm undecided on this, and would welcome any thoughts. In theory, during the cold months, the density of air is higher and so more Oxygen is sucked into the engine. This would imply a higher Octane grade is necessary to take advantage of this and avoid knock. I'm not sure what other additives are used during the winter which may counteract this tendancy. Obviously the engine computer is monitoring the incoming air and compensates for the pressure and temperature, and as stated before, the knock sensor is altering the ignition timing to eliminate knock.
The cheapest and crappiest grade of fuel that you can get in Europe is 91 Octane, although this is now very rare, as those people who tended to buy such fuel have all migrated over to Diesel because of the better fuel economy. In the UK you cannot buy 91 Octane, the lowest grade is 95 (premium is 98). That is why the owners manual with your car references 95 and 98 Octane.
So I imagine that Jaguar, Land Rover and Ford have to buy 91 Octane specially for their testing facilities. All calibrations are normally done using 91 Octane as the baseline fuel for engine development. I'm not sure how Jaguar would mimic 87 or 89 grade without getting it made specially.
So - any comments on the winter fuel recommendation?
Hmmm, never heard of that before..That???s a new one. I do know that they manufacture a different fuel for winter months..Less oxygenated I think. No sure.
Last winter I accidentally put 89 in it (the pump guy didn't hear me I guess and it was too late to do anything about it) saved 5 bucks I think. Anyway, long story short.....never again! lol
I suppose you can try it out for a test and see what you think...all depends on your driving style I suppose. I'm more aggressive and need that extra punch, but if you're a slow and easy...I suppose 89 wouldn't hurt for a short term anyway...
________
Kitchen Measures
________
Kitchen Measures
Guest
Posts: n/a
[8D] Gasoline octane is a common question and the recommendation from the manufacturer is usually recommended. But what is the trade-off? I have used 89 on my 25L, 03 SPORT since new and runs great and the odd time I did use higher octane have not noticed a difference in mileage, nor performance. The car adjusts itself. Porsche and Mercedes engineers have admitted that all cars are made to run on ANY octane because in many places in the world only one octane is available. So you will only trade off a little of mileage and performance according to the engineers that designed the engines. It will not harm the car. I do know oil companies make a fortune on higher grade....[:@]
I don't agree....yes, cars will run on any grade....that's becasue the computer adjust the timing and such..trade off is....carbon build up, engine damage do to sever pining (you won't hear it, ping sensor adjust) poor fuel economy and poor performace.
If you read your owners manual, it states that for best performace, fuel milage and perventive maintenace, for the Jag, use 92 or better...the higher compression engine needs it. Your actually wasting money by using the lower octane fuel.......
But hey, if it works it works..
________
Jaguar Mark 2 History
________
Guest
Posts: n/a
I know I have been through this with people back and forth. The reality is in many places where high performance cars are sold there is only 1 octane rating and that is why they have variable octane knock sensors. But it get too emotional for many people to think that their baby can run on cheap gas. I am only saying you will not destroy your car.
Octane is the most important issue when it comes to selecting the proper gasoline. Octane is a numerical rating that indicates a fuel’s resistance to detonation. The higher the octane number, the more resistant it is to detonation. Higher octane allows an engine-builder to create higher cylinder pressures to make more power. If your engine does not detonate, rattle, or ping on 87-octane fuel, there is no advantage to using a higher-octane fuel. Also, a common fallacy is that higher-octane gasoline burns faster or slower. As octane increases, the components that increase the octane chemically react in the combustion process to merely prevent detonation rather than change the burn rate.
Gasoline Octane Facts
Printable Content
When you pull into a gas station to fill your car's tank, you almost always have a choice of several kinds of gasoline. The majority of pumps usually offer a product called regular; other pumps are labeled premium, super, or something similar, and their product sells at a price about 12 to 13 percent higher than the price of regular. The difference in name and price is based on the gasoline's octane, with regular gasoline having an octane of at least 87 and the premium or super fuels having an octane ranging from 89 to 95.
What is octane?
Octane actually has two definitions.
One is chemical: Octane is a flammable hydrocarbon liquid that along with other hydrocarbons -- pentane, hexane, heptane, and many others -- is refined from crude oil and makes up the blend of chemical components called gasoline.
A second definition: Octane is a measure of a fuel's tendency to knock or ping when it is mixed with air and burned in the cylinder of an engine. This octane rating is not based on the amount of chemical octane in the gasoline. It is called octane because pure hydrocarbon octane is used as a knock standard, with a rating of 100. Gasoline, made from a blend of octane and other hydrocarbons, may have a higher or lower rating, depending on its tendency to knock.
How is octane rating determined?
Gasoline is subjected to two testing methods to establish its octane rating: one, called the motor method, runs the gasoline in an engine under load; and a second, the research method, runs the gasoline in a free running engine. The research method gives slightly higher ratings, and the octane number displayed on the pumps is an average of the two methods.
Octane facts
Knock occurs when cylinder pressures are high. It is normal for an engine to ping a little at full throttle because cylinder pressures are very high at full throttle. Engine knock, however, should not be ignored since it can result in serious damage to the engine.
High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when cylinder pressures are high.
If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in switching to higher octane gasoline.
If your engine knocks or pings, it does not necessarily mean something is wrong with the gasoline. It could be a problem with the car's ignition timing or exhaust gas recirculation. On high mileage engines, a carbon build-up in the cylinders can increase cylinder pressures and cause knock.
Many of today's new cars have fuel-injected engines that need, at least periodically, to use gasoline with a detergent additive. They do not need high octane gasoline unless the auto manufacturer recommends it. Some gas stations, however, have detergent only in their high octane gasoline. If this is the only way you can get a detergent additive, you may want to buy high octane gas occasionally.
Always follow the auto manufacturer's recommendations in your owner's manual.
Octane myths
High octane gasoline improves mileage.
In general, if your car is designed to run on 87 octane gasoline, high octane gasoline will not improve mileage. If switching to high octane gasoline does improve mileage, you might find that a tune-up will give you the same improvement on 87 octane gasoline.
High octane gasoline gives quicker starting.
No, it doesn't.
High octane gasoline increases power.
If your car is designed to run on 87 octane gasoline, you shouldn't notice any more power on high octane gasoline. Again, if it does make a noticeable difference, you may need a tune-up.
High octane gasoline has been refined more -- it is just a better product.
Additional refining steps are used to increase the octane; however, these additional steps do not make the gasoline any cleaner or better. They just yield a different blend of hydrocarbons that burn more slowly. The additional steps also increase the price.
Printable Content
What is octane?
Octane facts
Octane myths
No, it doesn't.
Thanks.....if you can use any grade gasoline other than the minimum required, would you subsistue your oil for something less than required? I don't think so.
Nuff said.
peace.
________
Iamhotlikehell
Nuff said.
peace.
________
Iamhotlikehell
Guest
Posts: n/a
See, that's why it gets emotional...... use what you want as far as octane is concerned. We went through the same emotion on another car site I belong to. Just knowing what octane is designed for (higher compression motors for performance) yet the Jag is 10:1 which is right in the middle. But if you sleep better with higher octane. Go for it. Oil? I use synthetic since new.
ok..ok...you use synthetic...I use Castrol GTX and primum fuel.
all good...
________
CROSMAN SAH02 AIRSOFT PISTOL HOLSTER
all good...
________
Fuel octane affects engines quite a bit actually. I had a 96 honda 900rr crotch rocket and could definetely tell the difference between lower octanes and higher octanes. They suggested using 91 and higher in the bike and you can totally tell the difference in fuels. The amount of performance lost to using lower grade fuels is detrimental to motorcycles. You may not realize these things in a car as they weigh 3000-5000 pounds vs. my bike with wet weight barely tips over 400lbs. wet (wet meaning with all fluids.) You flick the throttle on that bike and you notice hesitation, inconsistencies, and lack of overall performance! You may not notice these in a heavy car as they don't react half as fast as cars. Personally I'll stick to using whatever the manufacturer suggests. My sister has a lincoln mark VII with a high perfomance 5.0 and if she doesn't put premium fuel in it the car knocks! We believe (mechanics as well) that the previous owner used low-grade fuel in the car which resulted in the knocking of the engine. In every dohc that I have heard of except for some 4-bangers premium fuel is recommended. Thats just me though, after riding my bike and noticing such a tremendous difference I'll stick to the recommendation of the people making the bike. I also noticed the difference between the 110 leaded (TURBO BLUE) fuel I put in the bike vs. 93! That thing purred like a freakin' lion-no joke! I also find that the smell was much better than the regular 93 fuel that didn't smell very good on the non-cat bike!
Amen brother..There's a reason why they have the higer octane fuel...If all cars took the same type fuel...we would only have one to choose from.
good info again...
________
Zoloft lawsuit
good info again...
________
Zoloft lawsuit
Guest
Posts: n/a
A couple of points:
A 96 fireblade has carburettors the a cable throttle control, and therefore the fuelling control is significantly different to the Jag engine which has multipoint fuel infection and drive by wire. However I agree with the comment about fuel grade affecting the bike; the power to weight ratio is so different the difference will be stark.
Being European, I couldn't believe that the lowest octane grade (95 RON) was higher than the highest US grade; engineered down to a price I suppose.... Hence my comments previously about what Jaguar would use to calibrate their engines in the first place - 91 RON, which is the common minimum grade available.
To my knowledge no testing was done by Ford in the USA, the engine was wholly designed by Jaguar in Whitley. Also at that time Ford were wedded to the use of their in-house EEC5 engine control module (now a Visteon offering), whereas Jaguar were standardising on Denso as their electronics provider. This would mimimise the amount that calibrations and control strategies could have been transferred between the two, and therefore any US based testing on Ford vehicles would have had limited use. On the basis of this I wouldn't go below 91 RON as it is unlikely to have been validated below this level.
I'd still like an opinion on why my Jaguar dealer would recommend 89 Octane for the winter here in Detroit.
I don't care if its carbs or fuel injected to me the bike had older technology which shouldn't have made quite a big difference with the bike not having the technology fuel injected engines have these days. My feeling is that if the bike can react like this on a bike why wouldn't it matter in a fuel injected computer monitored car. I just feel that in a car thats 10 times heavier you won't notice the difference quite like I could on my bike which was much lighter. I am convinced that if 91 is recommended on that thats what I'm going to do as well as in this car. I'd get it in writing from the dealer (jag of troy I assume) that they say its good to do that and when something happens blame it on them. Maybe they know a thing or two about these scammer gas stations who change the amount of water they add to their gas-had it happen before here in Michigan
