Gauge swap question.
Received 3,909 Likes
beardedjag, you are not stuck with your instrument cluster, but at the same time, you may find that it will disable your car if you get something too different from what you currently have. It seems to be a hit and miss thing. So, to get another instrument cluster with a build date near what yours is would be best, but it still won't garantee that you will avoid a trip to the dealership to get it properly programmed.
I wish the answer was more black and white, but that is what we are finding out.
beardedjag (08-13-2014)
beardedjag, to the best of my knowledge, all X-Types came with the same instrument cluster. They are all black faced gauges. So, I guess that is going to eliminate that option (atleast the OEM option). That leaves you with the overlay option.
As for doing LEDs, you need to know what MCD rating LED they used. THe problem with LEDs is you have 20 million different light intensity ratings for the LEDs and not getting the correct rating LED can lead to spot lighting of the instrument cluster or lack of light even with the dimmer dialed all the way up. LEDs have a few ratings that you are going to need to know. THe one that will give you a little bit of variance with is the wavelength of the LED. This is in short the color of the LED. THe problem comes in that if you ever have to replace the LED or you are needing to buy LEDs from multiple places, you need to make sure you get the same wavelength. Otherwise you are going to have different colored lights. The second value you need to know is the MCD rating. This is essentially a measure of how much light the LED is putting out. Higher the number, the more light. To play in with the MCD rating is the angular viewing of an LED (also written as theta over 2). A lot of your very bright LEDs are very bright, but over a very limited angle. In the case of your instrument cluster, you are going to need something with a very wide angular light distribution (atleast 120 degrees, if not more). Get too small of an angle and you are going to have bright spots in your instrument cluster and places where there is no light.
If you need to know more about LEDs, let me know. I work with electronics and do a lot with LEDs.
Well my friends took a little surfing but look what I found
![Gauge swap question.-8204_jaguar_x-type_cream.jpg](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/93012d1480973518t-gauge-swap-question-8204_jaguar_x-type_cream.jpg)
Jaguar X-Type KMH to MPH Speedo meter clocks. Dials
Looks like I am taking the wife out to dinner tonight and a little arm twisting
The sport models have green faces. I have one sitting in a box waiting to be installed, but as stated, I have to get the thing programmed after its installed, and the jag dealer wants an hours pay just to program it, that's about 120 bucks haha. A friend of mine that is a manager at another shop said he can do it though.
Paulc732 (08-13-2014)
Attachment 93012
Looks like I am taking the wife out to dinner tonight and a little arm twisting![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Attachment 93012
That looks to be for a diesel model, the rpms only go to 5k...also they are saying its for cars with KMH to convert them to MPH so I'd worry that the numbers might not actually line up with where they would be on a car that already reads in mph. So I'd check with them first. The cream color looks cool though.
The numbers will line up I had an MR2 Japanese import that I did this to when I lived in the UK its just a different scale on the gauge (which matches the MPH gauge we have).
I have emailed them and asked if they can do the gauge that has the rev counter going up to 8K in any other color the C307 and C312 which are the ones we would be interested in.
I shall keep you all posted as soon as i get a reply.
I also have my brother in law looking at junk yards in the UK see if he can find me a 2008/09 cluster with the metallic background
ok Guys and Gals
I got a reply here is what they said
Hi,
The 8204 is for the diesel model
We can produce them or the (C312) in almost any colour you require.
One off orders are always expensive due to the set up and production costs.
If several of the same colour are needed then the unit price is more realistic as the setup costs are shared.
As a guide, we can supply 10 IDENTICAL dials in the same colour at £75.00 each + postage.
Kind Regards
Clive
so if anyone is interested looks like we have to get a group order
wonder if one of our friends in the UK would be willing to set this up.
Hi,
Kind Regards
Clive
Beardedjag, keep in mind that 1) the price is in pounds, not USD, so, you need to do the conversion for how much it is going to run, and 2) how much will the shipping be from England to the US on an odd-ball size package? You may find that the shipping alone may make things unrealistic. Check into it as the acceptable price is what you are willing to spend.
Ok they say they can do the silver or "get very close".
I have requested a quote to get these all shipped to me.
all I need now is to get some pre paid orders
I shall ship these to you guys AT COST, Do not want to make money of you guys as long as I can get enough interest, I am not willing to sit on these at nearly $140 a pop
so........ who wants one
need at least 10 to make this work more would be better.
