Gearbox and Engine System fault
I was driving on the HWY 12/10/10 as I tried to turn on cruise control my car lost power wouldn't go over 10 miles the message gearbox fault, and engine system fault appeared. I pulled over off the hwy turn the off, my car started system message reset. However this morning my car would not start temp outside 17, sounds like a belt maybe loose. Dealer stated issue is with gearbox and engine system fault cost $1912.79 to repaired. Dealer stated the issue with gearbox may have (air) in engine which cause the car not start. Yes this what I was told today. Has anyone experiences this issue before?
Jag 2002 X 3.0
105256 mileage
owned since 2007
$1912.79 repaired the cruise control, gear box, and labor.
Jag 2002 X 3.0
105256 mileage
owned since 2007
Jag 2002 X 3.0
105256 mileage
owned since 2007
Jag 2002 X 3.0
105256 mileage
owned since 2007
I had a dealer tell me I needed to replace the transmission (($3750) because battery acid had dripped on the transmission wiring harness connector that runs underneath the battery compartment (great engineering). They said no they couldn't splice in a new connector. Well I'm hard headed and couldn't see the sense in replacing a perfectly good trans. I cleaned the connector with baking soda/water dried it, sprayed it with clearcoat then silicone and wrapped with electical tape. Cost probably less than $2 savings priceless. I haven't experienced any problems with that connector in 3 years, and the trans is working perfect too.
