Gearbox Fault!
#82
#83
Jag xtype 2.0
I have an issue with gearbox fault. There was some pop spilled on my gear box after the gearbox fault came on dash board I took it to a local mechanic told them what happen because my car wouldn't start after this. So they cleaned it out and everything was supposedly fixed well i drove it home n later that night the same code came back on and it won't start again and now the dash is saying transmission fault and the car still won't start
#88
Transmission default
Hello..i have a 2002 jaguar x-type
And i also had the GEARBOX FAILURE..
And all i did was install a new cd player and thats how my gearbox code came up ..so i took it to the mechanic and he said he rest something...i wasn't sure what it was
But it came up again and and i called he told me that he was busy and he really didn't do anything to it last time but mess with the wiring harness
..so all i did was unhook the wires from the stereo system and put them back couple of times and there is no GEARBOX FAILURE..hope you have the same situation and hope this helps you too...
#90
Inertia Switch Tripped
Unable to start 2004 Jaguar X-type this morning. Code on dash read Gearbox Fault. After a hour of reading and watching videos I came upon this suggestion. "On the passenger side kick panel you should see a small opening. Put your finger in there and you should feel a button type switch. Push down on it if it popped up. Try boosting the battery as it just may be weak." The button was popped and after I boosted the battery the fault was cleared. Simple solution for the majority of members on this forum. For anyone else overwhelmed with the idea of exchanging a gear box or locating the ECM/TCM hope this helps.
dmatthewman
09-30-2015 10:10 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
