Gearbox fault
I have encountered a gearbox fault 3 times now. Each time it puts me in limp home mode and each time it was raining. I have read that I need to seal my TCM or ECM. I am not really able to tell which one is the correct one from what I have read and have read it is on the drivers side and also that it is on the passengers side. Can someone please help me before it rains again?
Here's how one guy did it. Should give you what you need.
How to waterproof X-Type TCM and location - YouTube
From the stickys at the top of this forum Workshop Manual in PDF. (thanks to LCGI) is a link to the manual for the X-Type which may be of some help.
It may be a good idea to start a new thread with your specific problem and more info about your car and how this error came about. Also go to the 'User CP' at the top of this forum and add your car details in your signature to help members know easily what we're talking about.
NoHub55 (04-26-2016)
Check the connectors to the TCM, ECM, and ABS modules. If you have a ABS code coming up, the module is probably fried.
Check and clean your ground connections, especially at the battery terminal.
If you have the TCM removed, make sure you check for corrosion on the circuit board and connectors.
innzane
04-03-2016 08:43 PM
