Gearbox Fault ..
Now this is a problem I’ve been suffering with for some time, but I’ve listened to “expert” mechanics, but none of their advice has worked… I’ve replaced the battery, the right side rear wheel Speed Sensor, etc etc ,,, but my car continues to go into 4th gear in the automatic, once the car reaches, normal engine running temperature. Plus, the, brake light is on at all times. SO, please find me a mechanic that can take my car,,, An Xtype, 2003 Jaguar, Automatic, Right Hand Drive, 2.1 Petrol V6 engine, and fix my problem… You know I’ll love you for evermore 🤓👍🤓
The 'brake light is on at all times' has to be a clue for other X-Type owners to understand what's wrong with your transmission.
https://www.jaguarforums.com/forum/x...-stays-165591/
first check
https://www.jaguarforums.com/forum/x...ts-stay-95949/
Second check
Oddly can sometimes cause cruise control problems =
https://www.jaguarforums.com/forum/x...ts-stuck-1949/
first check
Second check
tigerspeed911
07-12-2013 07:21 PM
