Gearbox fault message
So I went out and started my car this morning and noticed a gearbox fault message on the display. I turned the car off, started again and proceeded on my way with no messages. Car is driven about 100 miles a day with no issues and I have had no cause for concern. Even after I restarted the car it rode and drove perfectly. I did the OEM scan to see if any dtc messages were present and the only ones were D900 and E510 that I believe have been there awhile. Any ideas on further testing I can do to mitigate a possible future issue? I am not sure I am comfortable chalking it up to a fluke but understand in the end that may be the case. Thanks in advance for any suggestions!
I am getting the same intermittent message together with the engine heater coil flashing. Turn off - turn on and everything resets.
I had this four years ago and it was the EGR valve. My garage said lock up the transmission and give it a few miles at 3,500 revs and blow the valve clean.
That has seemed to reduce the frequency of the messages but the valve wuill need replacement again in due time
