Getting ready to work on the new X
I bought my X last weekend. I knew it had a check engine light on when I bought it. Code pull said #6 cylinder miss. I got a new coil in the mail on Friday. I also got new plugs, oil, oil filter, air filter and PVC valve.
I am letting the wife sleep in as we have an 8 week old son and she gets up in middle of the night to take care of him. As soon as she gets up I am heading out to tune it up and hopefully get it running right again.
I tried yesterday to sync my phone to the car using the instructions on here without success, so I am hoping that the tune up will have a better ending. I also got the new fuel door in the mail too. The Daytona 500 is today and the weather is not so great so I hope to at least get the tune up done before I get a soaking.
It does display no phone so I have an almost new Kenwood head unit with bluetooth and phone capabilities so it almost is a no brainer now.
I raised the hood and took off the plastics and found a mouse nest next to the #2 coil. Yep it sat for a while. I got the front plugs changed and the #6 coil with no problems. Coil #6 has had some bad arcing on the end so I am glad I pre ordered the new coil. Started removing the upper intake and one of the bolts in the rubber grommet would just spin. I ended up pulling it out with the insert still attached to the bolt, well this is not going to be good.
I got the insert loose from the bolt and I ended up re-gluing it back in with some quick set J B Weld. I do not know who worked on this car last but it was have been Gorilla Garage as every bolt and the spark plugs were insanely tight. I put anti-seize on all the plugs and intake bolts on reassembly.
Let the J B weld cure and put everything back together. Cleared the codes, crossed my fingers and fired it up. HELL YES!!!! No codes and the X idles and runs superbly!!! Didn't get to chance to change the oil or fuel filter as the rain had set in and I did the intake reassembly in a drizzle.
This is the first time I have ever worked on a Jag so all in all it went pretty well. I can't wait to finish tuning it up, install the fuel door and get to work on cleaning it up. I think this might just work out.
Gerard Radimaker
02-03-2016 01:24 PM
RobinGa
01-28-2016 10:47 PM
