Global function
Guest
Posts: n/a
Ok, so after reading in the other post about people getting this programmed I had to try it.
It works fine if I hold the key in the door, but it does not work via the remote by holding it down for 3 seconds on the second lock function doesn't work. Plus when you do use the door key you have to hold it until everything is closed. Is this how it's suppose to work?
Guest
Posts: n/a
Guest
Posts: n/a
Guest
Posts: n/a
I agree that the global close function would be great if it worked with the remote. If this is indeed how it is supposed to work, let me know, and I will get mine programmed. Mine only works with the key in the door, which is kind of useless. If it starts raining, it would be nice to sit in the building and global close the windows and sunroof.
yep, it is a feature that has to be programmed. i had to go to 2 dealers to get mine done - first one said it was impossible on an 04. funny thing is, when i drove with my dad to get his 03 about a month ago it was not turned on. we asked that it would be, and the service manager told me that is not an option on any jaguar. so we took a little stroll out to mine, i showed him that it does exist, and 10 mins later my fathers was working. no idea how they did it as they drove the car away into a service bay to do it.
Guest
Posts: n/a
Ok so from what I've read here it sounds like the key in the door is standard on ALL.
The "Global" function is programmed into the remote somehow, so I will have them do this next time I take it in.
Which will be soon because this morning my door locks didn't work the way they normally do. I usually hit the lock button twice to hear the horn just so that I know it's locked I did that this morning and it didn't sound the horn. Then the remote didn't work to unlock the doors but did release the trunk then it did lock the doors and rearm the car alarm, but still didn't sound the horn. So I'll have them take a look at that and hopefully get the "Global" function enabled at the same time.
turning the key in the door to close the windows is not part of the global close feature. that is enabled on all X's i beleive. well, it was on the 3 X's that are now in my family, but none came with the key fob closing portion, they all had to be 'programmed' by a dealer.
Guest
Posts: n/a
Guest
Posts: n/a
philwarner
28
07-11-2017 10:21 AM
