Gltch?
Clackavosticus (07-23-2018)
Test Result:
Rated: 910 SAE
Measured: 583 SAE
"Bad and replace"
State of health : 64%
State of charge: 100%.
The technician said I might be able to improve things with a battery charger (which I can't use in my communal carpark) or a long drive.
I have booked her in for replacement battery on Saturday - the current one should last until then. Cost $295 AUD. A little expensive but cheaper and more convenient than doing it at the side of the road...
If after replacing the battery you have the warning light illuminate at any point, there is another suspect - very common: internal corrosion of the battery cables (and this can happen even in non-winter locales): the symptom will be the same: the warning light coming on intermittently. The test: feel the connector end of the battery cables (one at a time). If one is hot (beyond the underhood temperature - one hotter to the touch than the other, then you have found the guilty party. This was the case in one if our X-Types, solved by replacing the + cable in our case.
Fitment of the battery is included in the purchase price - I'd save nothing by fitting it myself....
Yes, with respect, you are wrong about this. I live in a "no winter" , very temperate-climate area - many years not even a frost- so the issue of road salt in the environment and subsequent corrosion simply does not exist (and the car has never been out of this environment since the first day in service).. Yet the + battery cable did present with very high internal resistance (the sign being the battery warning light and the tes being the too-hot-to-touch cable end). Replacing the cable cured the issue.
My understanding of how battery cables corrode mainly is this. As your battery functions normally it releases hydrogen gas from the sulfuric acid inside (yes, even "sealed batteries release the gas). This causes corrosion.
Battery terminal corrosion is easy to identify. It’s the white, green or bluish stuff on your vehicles battery posts, battery terminals or battery cables. The white substance which you see around battery terminals is either lead sulfate or anhydrous copper sulfate. Anhydrous copper sulfate changes to blue color when exposed to moisture. The bluish material which you see around corroded battery terminals is hydrated copper sulfate and typically experience with copper connectors.
This corrosion even if not optically noticeable, "wicks" into the battery cables (think a lantern wick) causing failure.
When you wait way longer to do maintenance on your battery and the corrosion is optically visible on the negative post, this indicates undercharging. The main culprit in undercharged batteries is that fact the alternator is not given sufficient time to replenish lost battery capacity due to the electrical load demand of the vehicle, and relatively short uses of the vehicle.
If the corrosion is on the positive post, this indicates over charging.
