going through tires on front
My sons 04 x type is eating tires on the front in a short time. I had a 4 wheel alignment done and new tires put on in december. now the tires are starting to feather again. I was told it was in tolerences for toe in but on the edge of the factory specs. They do not know what to do. It is an 04 6cyl x type. The front end is tight. The tires are expensive. Any ideas? They thought maybe new front springs but I question that. thanks in advance, bob
Received 3,923 Likes
mphy98, you may want to check the strut bushing at the top of the strut (where the strut mounts to the wheel well). If you have some play there, that can lead to play in the steering, which then leads to excessive tire wear.
Also, do you find that when you are travelling at about 65 mph, that the steering wheel has a slight wobble back and forth? If so, this is the front tires fighting each other due to the alignment being slightly off. This will lead to excessive wear on the inside edge of the tires.
KarimPA
09-12-2015 08:15 AM
