Good place to tap 12V inside car?
I want to install a ham radio in my 2003 X-type. It looks like the guys who designed this never thought that anyone might want to add accessories that would tap into the battery, so I'm trying to find a good spot to tap in.
I need 13 amps.
Is there a good spot in the under-dash fuse box?
I need 13 amps.
Received 3,898 Likes
Sone, if you are needing that much power, then I would recommend running a new line from the fuse box back to where you want it. Most of the circuits under the dash are going to be limited to 10 amps (based on the fuses) and will have less capability as you turn said functions on and off.
If you do not want to run power through the firewall, then you should be able to find power back in the trunk/boot) of the car on the driver's side. This is where the factory radio stuff was powered from and you should be able to find something with that rating there. There is a few power lines back there that you should be able to access. the fuse for these is rated at 15 amps, so, that just gets you over the hump. The bigger issue is whether the wiring between the fuse box and the spot in the trunk is capable of handling that current. Your best bet would be to gain access to fuse F72 and run a new wire from there. Granted, you have a stereo with the rear CD changer or other stuff back there, this will cut power to that stuff.
I need 13 amps.
I need 13 amps.
The ignition switched supply is fused in the same fusebox at F 22, 20A but then runs through a standard relay, R4, that is not usually fitted at build but easy to buy and fit.
With the glove box removed, the connector is usually tie-wrapped to the steel bar/tube running over the car, under the dash. It can be difficult to spot, but it is there!
Sone (10-23-2021)
