to grease or not to grease
Received 3,909 Likes
suprasix30, yes, the bearings should have been pressed in dry. Granted, the fact that you greased them shouldn't make all that much of a difference as the fix is supposed to be tight enough that all the grease should have been squished out to begin with. If you have a bearing that is moving on you, then you have a different issue (ie, worn hole on the spindle or too small of a bearing). We are talking only like 0.001" or a very small fraction of a millimeter. We are not talking a whole lot here. Pressed together items are made with very tight tolerances and something as simple as being rather aggressive with sandpaper inside the spindle to clean up the rust can be enough to cause problems.
suprasix30 (03-04-2014)
JimC64
10-11-2015 09:04 PM
Richard_gib
09-12-2015 07:08 PM
