half-shaft splitter. help?
Hey y'all. I need some help.
This weekend, I'm working on the front end of the car. Replacing springs, struts, brakes, etc. etc.
I'm also replacing a leaky right-side half-shaft seal (at the t-case)
Here's the problem: I can't seem to separate the half-shaft from what I'd call the T-case out-put shaft. JTIS says I need a special tool (307-442, see it here: http://jaguar.spx.com/PDF/Cabinet_3_Drawers.pdf )
Have any of y'all ever done this procedure? I have a large 'pickle-fork' (ball-joint separator) that won't even get it started. IS there something I'm missing? what do I really need here?
Thanks in advance.
Dan
Thanks in advance.
Dan
Guest
Posts: n/a
RE: half-shaft splitter. help?
Not sure which seal you are attempting to change. there is an Oring there on the RF that is srtaightforward to change, but not common problem.
The other seal for the RF shaft cannt be changed with the transfer case in the car. It is quite clear in the JTIS that you cannot pull the shaft out more than a few inches. If you pull it all the way out, you will damage another inner seal.
So, I cant figure out why you are trying to pull the shaft out?
from the JTIS, it appears that it CAN in fact be changed, as the seal itself is the same diameter as the link shaft, and should slip over the shaft, without having to remove the link-shaft. (SORT-of confirmed by my dealer ) But it is necessary to separate the half-shaft from it. Interestingly, my dealer told me that they CANNOT GET parts for the T-case, because it is "non-serviceable". But they sold me the seal just fine.
here: check this link, I've scanned-in the blow-up that the dealer printed for me when I bought the seal.
http://www.dansfam.com/images/rhseal.jpg
we're talking about seal #6
On a side-note: what does that o-ring seal between the link-shaft and the half-shaft do? Is that really a wet-? Why? Why would you POSSIBLY want to have oil all the way out the length of that link-shaft?
well, a few good yanks and the link-shaft will be coming-out with it.... I know, 'cuz I already tried that.
I get something like 7-3/4" (200mm) of link-shaft movement before I get to throw-away the T-case and start again.... Not something I want to be doing. On my first good pull, the link-shaft came-out about 3".
And this is a really funny post... since we're talking about 'yank-ing', and 7-3/4" and all.....
Guest
Posts: n/a
well, after much grief, I got 'er done.
New seals. New half-shaft on the left-side, since I discovered it was in poor shape as I was replacing brakes, springs and struts.
New Brakes / springs / struts all the way around.
New fluid in the T-case, Diff and Manual Gearbox.
new "scoop-thingy" to divert air to the t-case.
what else...... ? ?
oh yeah: new smell inside.... one that doesn't smell like hot-90wt oil!
I'd like to say the things like a new car... but it's really not. The Jag suspension is still too soft for me (even after going with the 'sport' springs and struts).
But at least I can quit worrying about it all......
what else...... ? ?
Guest
Posts: n/a
ORIGINAL: McJaguar
are you saying you did both?
If you did in fact do the right hand seal.. how did that all work out?
can you give a quick play by play on that seal?
Tijoe
04-02-2021 11:10 PM
1964Daimler
09-08-2015 11:54 PM
