Hard shift from first to second when driving slow
when buying the oil, as dell states.... make sure it says "MULTI IMPORT" on the jug....there is an almost identical oil on the shelf right next to it so its easy to mess up.
check each bottle carefully, i once bought one of the other types as someone had put it back on the shelf in the wrong place
can you supply the specs here please?
Yeah there are numerous "high end" fluids that meet the specs like amsoil, etc. Lots of debate has gone on. If one over the other makes you feel better, use it. As another member said "while you're debating, your fluid is getting older".
I'm more of the camp of chemistry = Advil is Ibuprofen, Tylenol is Acetaminophen, Bayer, Ecotrin, Bufferin Aspirin is acetylsalicylic acid. It's the same product and chemical composition so why pay for name and branding?
well DUH!.... you just replaced ypur old crappy water-like oil with fresh oil.....an oil change with any brand oil will yield the same result.
what made me laff on royal purple website was the positive customer feedback "after using royal purple my transmission felt much crisper and has milage improved"
chater210
02-12-2014 11:44 AM
Dan Bennett
08-24-2013 08:47 PM
