Has anyone ever tried Dynamat?
I do apologize that one of my first posts is a question.
I was wondering if anyone has tried putting Dynamat or another generic brand of sound deadeners in their trunk. I have a subwooffer in the back, I know i'm a basshead, but I love it. I can't stand the rattling when listening, especially on the when listening from the outside.
I have a 04 X-type
Thank you for looking, have a great day!
I have a 04 X-type
Back in the day I used to install sound systems. Dynomat is one of the best additions to any sub. When I did a sub install I would take all the padding/mats out of the trunk. Spare tire and all. I would line the entire trunk with dynomat. including the trunk lid and the license plate and then reinstall all the padding and mats for the trunk. This way you never know the dynomat is there and you have zero rattles. In some systems I had to double and triple up the stuff. Only downfall is its very heavy. They do make light weight alternatives and I have seen people just use spray foam, which to me is not smart, but to each their own.
To do it correctly start by measuring and cutting to the correct length. Take a heat gun or blow dryer and heat up the material on the back. once heated up apply to the car and make sure all parts of the dynomat adheres. You dont want air pockets.
Endothes (01-09-2011)
I bought the "off-brand" of the dynamat off ebay, and will never make that mistake in any car ever again in my opinion. I had enough to cover the entire truck twice plus came with a free roller . I brought the car to get my system installed with the
"fake-a-mat" in a one shot deal. When winter came around I noticed the material was peeling off the trunk lid. Called my installer and said he used a heat gun, roller, etc. The stuff started to get air pockets as another member said, and the bass was all over sounded like a empty barrel being beat. I now ordered the "Dynamat Extreme" and waiting for a warm day to rip out and install the new stuff. Plus I figured with the Jag, I should have bought the Dynamat in the first place.
I heard good things about fat mat, If any sound guys could chime in, How does the liquid sound dampening work that you "paint" on compared to the dynamat "stick" on?
I have dynamat on my floor - front and rear, rear deck and front doors. Overall, I notice a nice improvement to the audio. Not sure if the road noise is down because of it since I've had it since around a month after I got the x type back in 2007!
I have a 04 X-type
I have a 04 X-type
My X' has 2 12"s in the trunk, so I fully understand what you mean about the rattle. I found that it wasn't so much what i used but where I put it, here are a few trick to help you out:
- Remove the rear parcel shelf and install a 2" foam underneath, it prevents the rear parcel shelf from vibrating against the rear glass at low to moderate levels (really loud you are on you own). Also while you have the parcel shelf out install the sound deadener on the sheet metal. This help prevent vibration transfer.
- Remove the licence plate an install the deadener on the back of it (not the car, it's a PITA to remove)
- Remove the spare tire and install AT LEAST ONE layer, if not two in the spare tire well. Also make sure the spare tire is tightened down periodically
- remove the trunk lid liner and install a layer here. if you have the option: the spray on stuff works best here, as the biggest issue is the inner skin vibrating/flexing, and hitting the trunk lid X bracing.
These cars are not the most solidly built cars so they will always rattle, a little.
Here is where I have some knowledge. Anyone serious about doing "sound deadening" right should have a look here http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
As an aside, I've been lurking around here a while as a Jag seems to be in my future pretty soon I look forwards to learning as much as I can from eveyone here before I make my decision.
In my years of experience, the best (and cheap) sound-deadening stuff to use is old-fashioned carpet underlay; the stuff that is brown, about half an inch thick, and surprizingly heavy. It must be properly att. though if under a boot/trunk lid. I've done many-a-car this way and always reduced the road noise noticeably as one contributer said.
BTW, there is no such thing as a "sub" woofer. If a sound is sub-sonic, it means you can't hear it -- that sort of frequency is for elephants. What you really hear is the third harmonic of the original, otherwise known as 'false bass'. False bass is common with cavity resonant chambers that are too small. You need at least three cubic feet to get anywhere near proper bass, and I'd only go for double this. A dead giveaway for a bad chamber design is to see the cone bouncing around like a mad thing. Proper acoustic loading of the cone limits its excursions considerably, and yet produces much more proper bass actually in the air that is against your ears. Put your speaker and its enclosure in free air and then listen to what it sounds like. Usually very disappointing! If you listen in a car, your simply listening to one box inside another, bigger box.
Leedsman.
Leedsman.
Leedsman.
Leedsman.
HIP HIP for the bass heads!!!
I just got my two 12'' subs installed buy a shop that charged me $230, and couldnt even bolt them down! so pissed, im just going to valcrow the crap out of the box.. but i dont find rattaling to be to much of a problem, exept for the lic place, whitch is an easy fix.
Then again, Dynomat is amazing stuff, i had it in my 84 caddy whitch rattaled like an old tin can.... that car used to pound so hard my rearview mirror fell off lol
Oh and to Leedsman, no one likes a smart ***, there called subs, atleast that what it says on the box they came in.
