has anyone used Amsoil in X type Transmission and gearcase
Old 07-25-2015, 04:41 PM
bigbigbrig's Avatar
Default has anyone used Amsoil in X type Transmission and gearcase
I just hit 50,000 on my 2007 jaguar x type 3.0 automatic
I have heard the stories about these cars having issues with thermal breakdown of the transmission fluid so I was thinking of putting amsoil in it.
From what I have read this oil has a pretty high tolerance to heat and dissipates heat well. Any thoughts would be appreciated.
Amsoil's website suggests this for the transmission
-Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
and for the transfer case they recommend
-Severe GearŽ 75W-140 Synthetic Extreme Pressure (EP) Gear Lube
I have ran amsoil in drag cars before and it did well but the x type is no drag car.
Old 07-25-2015, 11:13 PM
Lubrication's Avatar
I use it and it's been truly a superb oil. It killed off a lazy shift from second to third after the first drain fill. I was NOT expecting such quick and complete results.
Also, for peace of mind, it states Idemitsu K17 compliance right on the bottle.
I also used Amsoil Severe Gear in the transfer case and rear differential.
It's excellent stuff.
That said, I use Mobile 1 Extended Performance for engine oil because I need that to be easily accessible at any time.
bigbigbrig (07-26-2015)
Old 07-26-2015, 05:34 PM
bigbigbrig's Avatar
Thanks for the reply. Its funny that you mention the lazy 2nd to 3rd shift. That is exactly what had me thinking about this topic. Every time I find one of these cars on craigslist it is always the same thing tranny shot. I'm thinking the amsoil will lengthen its life.
Old 07-26-2015, 06:22 PM
DPK's Avatar
DPK
DPK is offline
That's because Ford/Jaguar at the time was convincing everyone that the SEALED/Lubed for life campaign was the answer to lube oil and fluid changes....It was too late for a lot X's and some damage was already done, when owner's started wising up and began changing out the lubes and fluids more regularly.
Just to add in case you don't already know..make sure you purge all the OLD fluid via the cooler lines...as the torque converter is where the bulk of it is.
The following 2 users liked this post by DPK:
bigbigbrig (07-28-2015), mrplow58 (07-26-2015)
Old 07-28-2015, 10:52 AM
SaltyOne's Avatar
I have two 2005 x-types, both 2005 3.0 with auto trans.
I have the Amsoil extreme gear oil in the transfer case and differential of one and Royal Purple in the other. Both have quietened the driveline noise and I have had no issues with either.
I used Castrol Import Multi-car transmission fluid in both and it has improved the shifting in both cars, much smoother, though still not perfect. Several other folks on this forum have had good luck with this product.
I have done 12-15k miles in both cars since these fluid changes with no issues.
I used to use M1 engine oil, but recently changed to Castrol Edge in both cars which has improved gas mileage 10-15% in both. Also, the oil leaks from the sump pan gasket has stopped in one car and almost stopped in the other.
HTH
Eric
Old 07-28-2015, 04:18 PM
bigbigbrig's Avatar
Thanks everyone for the replies. I'm going to do the amsoil in the tranny, transfer case and diff. I'm interested in the difference before and after.
Old 07-29-2015, 12:09 PM
millertic's Avatar
Is there a sticky to replace the Diff Fluid? I've done the TC with Amsoil but couldn't find directions on changing the diff.
Old 07-29-2015, 01:37 PM
DPK's Avatar
DPK
DPK is offline
You get a lube oil sucker (like a big syringe) with a long thin plastic hose and suck it out via the Fill Hole..a little bit tough because it's so cramped back there, but doable...Then you can pump in the new lube with a hand pump till it flows out the fill hole...All these items can be gotten at the Auto parts store.
Old 07-30-2015, 01:53 AM
Does the car need to be level for an accurate fill? If not, what is the correct orientation of the vehicle for an accurate fill?
I did not level the car, so I suppose I may need to redo it.
Old 07-30-2015, 11:47 AM
DPK's Avatar
DPK
DPK is offline
Fairly level to be sure on the fill amount....
If you open the fill plug on a level surface and it dribbles out, you're fine....I know you have to be a very thin person to get under there without jacking it up...What I did was, fill it while jacked up and then let it down and let the excess run out..then jacked it back up again and put the plug in.
way2far
08-31-2022 09:26 AM
SD96XJ6L
01-12-2022 04:30 AM
Shawn Svacha
11-04-2019 02:47 PM
Raul Lara
09-14-2015 07:31 PM
dcvickers
09-02-2015 06:14 PM
Quick Reply: has anyone used Amsoil in X type Transmission and gearcase
