Have to stand on brake pedal at medium speed
When the car is cold there are basically no brakes, yet a hard pedal. after driving a bit al slow stops it's fine. If I have to suddenly stop it just wont no matter how hard I smash the pedal. I've been told booster, pads etc. Anyone familiar. it's an 02 x 2.5 automatic...please help. I was given a 650.00 price for a booster and no idea if that's the problem
There is a vacuum hose from the brake booster to the top of the manifold, with a check valve in the middle of it. Check for a leak somewhere in that line, either where it goes into the manifold or in the valve. (bulge in the middle of the line). Or just replace the whole line -$20 -30.00 on ebay. Just be careful in pulling the old line out of the manifold. Push down on the connector while pulling up on the line.
yes have a ck engine light on forever, but it's for 02 sensors. Is there a better way to check for a vacuum leak than by ear? i was thinking of spraying soapy water on it, but a vacuum leak will suck in nit blow out. I've been t a mechanic and all he did was sit in the car hold the brake and start it, the pedal went down an inch or so and he said booster, 625.00....don't really trust that
You mention your brake problem is when car is cold & gets better after it warms up. Does engine run rough during this same time, then smooth out as it warms up? --Also a good sign you have a vacuum leak. You can spray carb cleaner around where you think leak may be & listen for idle to increase where leak is. Only do when engine is cold & be careful as this stuff is extremely flammable!
daygoVR6
US Western
10-25-2016 03:07 PM
