having major engine issue please help
2004 x type 3.0 v6 I don't understad what is going on
it misses horribly under throttle
If you hold the throttle just right it smooths out and has power
I thought clogged cats I looseNed them up and seperated from the manifold and it did not change anything.
I bypassed my fuel pump power module and gave full power to the fuel pump didn't change anything.
What can I be looking at as an issue I'm not pulling any codes besides wheel sensor
Welcome to the forum.
A little more information would be helpful. How many miles? Has any other work been done? I don't know many that would detach the exhaust manifolds as a first step. Have you checked the spark plug wells for oil, the spark plugs themselves? Missing that bad it is unusual for no codes to be generated. How long has this been going on?
