Headlight Not Working On LH Side
Guest
Posts: n/a
I just replaced the headlight on my girlfriend's 2004 X-Type. I checked the fuse and it's ok. I put the voltmeter to the plug of the headlight and I'm not getting anything from it. The meter reads 0. Could it be a bad relay somewhere? Or maybe a bad plug? Any help I'd appreciate it.
Vince
Vince
ORIGINAL: VinceWood30
Vince
Vince
As silly as this may sound, but have you checked the bulb? Chances are, you're probably looking way too far into this and it's probably just that. Swap the bulb from the other side and see what happens. If you get the same result, then it's probably something you should look a little further into.
EDIT: I have a better idea! Just pick up an HID kit and then all your problems will be solved
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Received 9,010 Likes
![Name: cars.jpg
Size: 7.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/195605d1501336913-headlight-not-working-lh-side-cars.jpg)
ORIGINAL: SpartanX
EDIT: I have a better idea! Just pick up an HID kit and then all your problems will be solved![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
ThanksVince
ThanksVince
Jim
Guest
Posts: n/a
hi ... i just came in from a frustrating experience that is the same as this post. My 2002 x-type driver's side low beam headlight is out. I bought a new bulb and replacedthe old with it(i've replaced these things before just fine), but it still didn't work. So i swapped the bulbs between driver and passenger side, and still just the passenger side worked, sothe new bulb is just fine.
The wiring looks ok, it's all snug, etc etc ... but it just won't work. Anybody have any ideas of what to try next before i go an a trek to the dealer next week?
Thanks!
Brian
Thanks!
Brian
Each headlight (high and low beam, left and right side) is separately fused. One relay controls both low beam headlights and a separate relay controls both high beam headlights. If at least one headlight works correctly, the associated relay is fine. Also, there are two connectors in each headlight circuit; the main connector to the headlight assembly and the connector at the lamp itself.
Vince and Brian, I would suggest you verify that the fuses are OK (by voltage measurement with respect to chassis ground at both sides of the fuse) then verify that both connectors are OK (by voltage measurement at each lamp connector. I would also inspect (i.e., disconnect and reseat) the main connector at the headlight assembly.
Guest
Posts: n/a
Yeah good luck with that....welcome all by the way...and as they stated though go buy an hid kit and save yourself from having to get into the back of the headlight all the time. I replaced my headlights with sylvania silverstars with about 4 pairs before I said screw it and left it alone with the stock sylvania halogens...until I finally installed my hid kit...the whole kit only cost me $78.99 shipped...One bulb at the auto parts store is about $8-10 + tax for almost $80 you can have hids!
aquill1- An HID kit wont help if the headlight harness isn't getting any power. The HID bulbs need power to work too![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
That being said, I agree. If you are already putting that much time into playing with your headlights/wiring, why not upgrade? So far the best mod I've done to my X-type.
Tokay they said that they have replaced the bulbs before....thus me saying that they should get an hid kit is to fix that...read before you start preaching there bro...I'm not an idiot obviously if they aren't getting power the hid kit isn't going to fix it...[>:]DUH
Guest
Posts: n/a
FINALLY someone posts about headlights. Ok heres the deal i been threw 3 sets of headlights at first i thought i toutched the bulb. I bought a set of sylvania silverstars installed them properly stayed on for a few 1 burnt out then mins. after the other one blows after that happen went to jaguar dealer to buy the stock bulbs thinking the have a higer resistance paying over 60 for both bulbs so i checked the volts coming out 14.2 vlts when turing on the car after it drops to 14 flat checked the relays and fuses nothing is wrong so pleaaaaasssseeee someone help because i cant be runing around at night with fog lights and runing lights make me look stupid thanks
Actually the lights issue has been visited many times...use the search function and you'll find I bs-ed about it many times!![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Yeah I had the same problems....put 2 different sets of sylvania's in my headlights they all burned up and than I had those replaced at advance auto and put them in my fogs said screw the lights....than later last spring I bought another set of sylvania's to give them a shot and no luck...again put a few different sets of silverstars in and no luck. The stock sylvania halogens never gave me any problems though...the filament on the inside of the bulb is thicker than all aftermarket ones even the silverstars...I've tried about 3 other brands of lights to no avail...your best bet seriously is to just get a set of hids...here's my HIDS I paid less than $80 shipped...they look great! Really good quality kit unlike what I thought I'd get...2 others have the same set...
Guest
Posts: n/a
Can someone please send me the link for the HID kit? I'll pay the $80 for it if it means getting the car fixed and my girlfriend off my back about it. I checked everything I knew and nothing is working. It's cheaper than taking it someone and having them look at it and try to fix it.
How long do these kits take to install? Thanks
Vince
Vince
Honestly it depends upon you...at the most if should only take 2 hours and thats about an hour and some longer than it took me and everything I do usually takes me forever...all you have to do is pull the back covers off...remove the clip holding the stock bulbs in the headlamp....take those back covers out because you need to cut/drill a hole for the wire to go through....once you've done that mount the hid in the bulb mount...before that though the brown wire is - and the yellow one is +. connect the 2 wires (+ and - to the 2 wires of the hid kit) and than put the cover on making sure the rubber plug is on the hole you cut out...once I did the drivers side it took all of 15 minutes to do the passenger's side...I'd recommend doing the drivers because you can move the battery box out of the way enough to get at the back of the light and figure out what your doing...than its easy doing the opposite side which is harder because of everything that is in your way. LINK TO KIT ON EBAY...
Your price might be a couple of bucks cheaper as his prices sometimes change...keep in mind my kit took 3 weeks to get to me...it was the chinese shippers fault but none the less it happened! The wait was worth it after I got the kit and it was a nice kit...the 2 others with the same kit only took like 5-6 days shipped to their door...
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
rudelover2
09-11-2015 08:53 PM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
