Headlight problem
No, can't say i've heard of anyone having that problem....
Sounds like you may have a bad ground somewhere. Do your lights dimm somewhat when you come to a stop? Try honking the horn at night with you lights on and see if they dimm.
It might also be a bad alternator voltage regulator. You'll have to take it to the shop to check that out if you don't have a multi meter.
Hope this helps...
________
INFANT PRILOSEC
Hope this helps...
________
INFANT PRILOSEC
Guest
Posts: n/a
[:@][:@] OK I HAVE THE SAME PROBLEM I TOOK MY CAR TO A MECHANICE. SO THEY REPLACE THE SOCKET BECAUSE THEY SAID THAT WAS THE PROBLEM SO THEY DID PUT IN NICER HIGH GRADE LIGHT BULBS.[:@] THEY BURN OUT WITH IN SECONDS. IT WAS THE DRIVERS SIDE THAT WENT WRONG.THEN THE PASSANGER SIDE WENT OUT REPLACE THEM BOTH WENT OUT AGAIN [:@][:@] THE MECHANIC SAID DONT BRING IT BACK TO HIS SHOP[:@][:@] HE TOLD ME IT MIGHT BE THE HEADLIGHT MODULE. I CANT DRIVE WITH MY FOG LIGHTS AND RUNNING LAMPS PLEASE ANY ONE HAVE AN ANSWER LET ME KNOW ASAP I CANT SEE AT NIGHT[X(][X(]
Sounds like you may have a bad ground wire some where....
They need to check the electrical system, not the bulb....
________
DISABILITIES ADVICE
________
DISABILITIES ADVICE
