Headlight washer cover
Hello,
I need help fitting back the headlight washer cover on my 2008 X-Type as I used the washer and the whole bumper was frozen.
Can someone please tell me how to pull out the headlight sprinkler so that I can put the cover back? It is still attached to the sprinkler on one side andI may have to glue the other side.
Thank you!
R.
Thank you!
R.
Take care when you look at this.
The washer cover is fixed on using a sort of cruciform shaped piece of plastic that forms a sort of tiny universal joint ... allowing the cover to sit comfortably against the bumper when retracted.
This cruciform can sometimes become brittle and break. This can also happen to the lugs into which the cruciform clips. So take care, don't force anything and possibly have some araldite two part resin or some two part epoxy putty to hand in case a repair is needed / possible.
Mike
Mike
I was thinking of the two part resin myself but to get there I need to retract the assembly out of the bumper. How is it done?
The thing that annoys me the most is the fact that I saw the ice and thought that is bad for the washers and not later than 1/2hour I used the washer and the headlights were on auto-on. Does anyone have a workarround so that we can can use the headlights washer only when mean to?
Guest
Posts: n/a
you can have a helper grab it when it is spraying .. or just pull it out. The cover is not meant to come apart at that little universal joint, you need to get a small flat screwdriver and take the black shaft apart... I think it is obvious when you have it pulled out.
I am afraid to pull it out or use force since I have a tendency to break stuff even more trying to repair.
Does anyone have a repair manual to scan the section about the issue in discution? Or, is it available on internet?
How do you grab it in order to pull it out?The jointlooks very flimsy.
I did it.
Just pulled it out and everything is obvious. Just applied the 2part epoxy and wait to dry.
I called the dealer and they do not supply the cruciform joint alone. I have to buy the whole assembly (cover+joint+sprinklers) 55 EUR+VAT... and I will do so if the repair does not work.
Thank you all!
Thank you all!
I did it.
Thank you all!
Thank you all!
Emulators & Transformers - FIESTA-TECH
I have done mine today, 2 x aluminium cruciforms. Get a shoe lace, or string, loop it over the washer, pull gently and it will come out. You will have to hold it while you fit the cruciforms and covers. I fitted cruciforms to covers, then to the washer, let go and they retract.......
mike midgley (07-25-2014)
aholbro1
08-05-2021 05:02 AM
mikimogo
09-22-2015 08:09 PM
mikimogo
09-14-2015 08:34 PM
