Headlights turn themselves on
Old 07-03-2024, 06:04 AM
BradsJag's Avatar
Default Headlights turn themselves on
Hi everyone. Strange problem here.
My suspicions have been confirmed last night that my x type 2.0D had turned the headlights on by itself.
I noticed it a couple of times before where I turned the light switch off and the headlights remained either on or turned themselves on later.
I replaced the light switch recently which I hoped would cure it, but no, unless the new switch is faulty.
Last night, I looked through the window and I saw the headlights were on again. I just used the key fob to unlock, then relock the doors, which turned the headlights out.
Now I know what has been draining my battery and setting the alarm off. Obviously, I dare not trust when the headlights may come on by themselves again.
Any ideas what may cause this problem ?
Old 07-03-2024, 10:24 AM
Spikepaga's Avatar
Your fob might be broken. I kept on having a problem where the locks would lock and unlock as I was driving , and I thought initially the actuators were broken, but it was the key fob that was malfunctioning.
Old 07-03-2024, 10:45 AM
User 42324's Avatar
The fob can activate high beam but not dipped.
Old 07-03-2024, 11:39 AM
BradsJag's Avatar
I had another problem with the headlights, don't know if it is connected but several times when driving, the headlights seem to go up and down occasionally. I checked the adjusters etc, installed new headlights but problems still there. Can't reproduce the problem when it's stood. No auto-lights.
Old 07-03-2024, 11:41 AM
XKDreams's Avatar
What model & year do you have?
If you have a model with a can bus system, try this:
- disconnect the can bus connector at the central junction box. This will prevent any commands coming from the instrument cluster turning on the lisghts.
- if the lights don’t come on,( on their own) then something is amiss with the light switch or instrument cluster.
- if the lights still come on (on their own) thrn something is amiss in the central junction box.
Old 07-03-2024, 01:54 PM
BradsJag's Avatar
It's an X type 2.0 Diesel, base model, 2005, manual, estate.
It does indeed have a comprehensive CAN system.
I'll check out what you suggest asap.
Many thanks.
Old 07-03-2024, 02:01 PM
BradsJag's Avatar
Had a look on JTIS but can't find anything that could be called a central junction box. Could you help me further ?
Old 07-03-2024, 03:31 PM
User 42324's Avatar
If you're in Notts., get the car over to David Marks Garages or up to The Jag Specialist in Doncs.
BradsJag (07-03-2024)
malc4d
03-01-2024 09:03 AM
Svalbard
09-06-2023 01:18 AM
Makowish
02-22-2017 09:43 PM
bfsgross
24
02-25-2011 07:30 AM
yjmcb
03-23-2010 10:08 PM
Quick Reply: Headlights turn themselves on
