Heat
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Yesterday is was about 30 in the early AM. I had a doctor's appointment. I got into my 03 and left and the car had no heat. I watched the temp gauge to see when the engine warmed up the heat would get warmer, it didn't. I had the heat set at 75 degrees by the way. However when I pushed the defrost button for the front a blast of hot air came up thru the dash vents. However the foot heat never got really warm. Any suggestions? I should have kept the Mercedes.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Received 3,901 Likes
If you have hot air coming through the defrost ducts, then I would say you have a distribution problem. Something isn't moving to direct the air flow. Hopefully someone will reply with advise on how to correct this as I don't have a clue. I know I have a problem with my A/C not putting out warmer air on drivers side than the pax side and that's possibly caused by a door not closing completely.
Try running the system in "Auto", and follow this sequence. First, lower the temp to full cold (low), wait 5 seconds. Next, raise it to full heat (high). Now select the face vents. Next select feet. Finally select defrost. Wait 5-10 seconds after each selection. Lastly, select auto again, along with your desired temp. Let me know if this changes anything for you. Sometimes the servo's "lose" their position and need to be run through their ranges. I've seen this more than a few times.
I also want you to open your hood and tell us what the coolant level is in the reservoir. It is possible you may be low/have a leak.
C'mon man!!!!!!! I triple dog dare you to get a MB with the same mileage, same vintage at the same price you paid for the X and not have the same if not more issues. If the Benz was such a perfect car why don't you have it any more????
I had an older E300, and it nickel and dimed me to death, it had 55 series tires and was so uncomfortable on the concrete freeways because you felt every seam. I drive those same seams now and I have 40 series and I don't have to turn up the radio. My office window faces the largest Benz dealership locally and the amount of brand new Mercs being towed in every day would make your head swim.
I admit, you've had some issues, we all have, but they're not terrible, I had to do a reset on my sunroof, I had to do a reset on my heater as described above. Takes a minute and it's good as new. I know you've got mobility issues and maybe you've reached the end of your rope with the car. But factor in you do little tiny runs as far as I can remember, I take mine out on the highway once a week and tromp on it to blow out the crap, knocking on wood it has proved itself, my commute is 40KM each way, in traffic, average speed of 33 KPH, last week a foot of snow and the X just fires up every morning, and gets me there.
When I picked up my X in April '09 it was still pretty cold out, and I wasn't getting and heat out of the vents, even after the car warmed up. After cursing the climate control system at great length, a few days later when the car overheated on the highway I found out why. The old cracked nipple on the coolant tank and the resulting slow leak had drained enough coolant that there wasn't enough fluid left in the system to be heated up for the fan blowing across it to generate warm air to be blown into the air ducts. The nipple that cracks is the one near the bottom of the tank toward the center of the engine with a 1/4" black rubber hose connected to it. Once I replaced and refilled the coolant tank, I had plenty of heat. So if you haven't already, I'd check that nipple and your coolant level.
