heat gets hotter as I accelerate
Looks like I might be low on coolant but not sure. The heat works fine but when I really want it to blow on high 90 degrees I noticed that once I hit the gas it blows much much warmer.
How would one fill their coolant - thru the over flow? Could it be anything else? No leaks anywhere or excessive smoke blowing from my exhaust...
RE: heat gets hotter as I accelerate
Make sure you inspect your coolant lines to see if any of themare cracked. It's listed as one of the common Jaguar X-Type trouble areas here: http://consumerguideauto.howstuffworks.com/2002-to-2008-jaguar-x-type-2.htm
Coolant leak: Coolant loss from broken expansion tank bleed tube could lead to overheating. (2002-06) [/align]If you engine overheats, the damage could be $$$
ORIGINAL: MattSteele
jimforrest (uk)
02-28-2019 06:42 PM
