Heated front windscreen Relay
I 'm wondering if the factory wiring is behind the dash and already in place except for the realy / fuses. There are at least 2 fuses, one for each side, the wiring is in each corner behind the dash as the right and left are separate so that would lead me to believe 2 relays as well. Good luck, if the wiring isn't there I wouldn't attempt it. It is a nice feature, only the drivers side works on mine now, the right side plug gets hot and corrodes after a couple of months, no idea why, but the defroster after the engine is warm is better.
Can't get to mine as car is buried under snow at the moment!
Jim
check my topic https://www.jaguarforums.com/forum/s...ad.php?t=32428
if you have questions PM me and I will provide all details I have.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi I am a memeber of another forum and have been having problems finding out the part number for the relay for the front screen as i am retro fitting it, a chap called jim helped me with the part number off his relay, 5m5t 14b192ea v23136-34-x62 (12v 70amp) Jag dealer still could not give me the jag pat number, so I have been to ford and they recogised the number straight away.
Here is the Ford part number F1425754
Hope this is of help to you
Hope this is of help to you![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Jim
the relays are basically free at a scrapyard. Every ford in the place will have several of them... worst case they charge you a dollar for a handful of them.
The front heated screen draws a lot of current. I strongly suggest that you DO NOT connect it to the rear defrost circuit.
The factory set up has a timer that only keeps it on for a couple of minutes. I suspect if you kept it on for 15 mins or so you would really overheat it. Not to mention the load on the alternator would be damaging. It is not designed to be on for extended periods of time.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
