Heater is not working...
hi, guys....
I found that my heater is not working.
well...I had to get back home....so...I drove without using heater for 10mins..
And I tryed..but not working....
When I got home, I opened the hood...the fan was working crazy...and I found that some water(I beileve its coolant)was all over the place.
Can you tell me what's going on???
RE: Heater is not working...
Yep. You have a coolant leak somewhere. The question is where is the coolant leaking from?
BTW, DO NOT and I mean DO NOT drive the car under any circumstances right now. Figure out where the leak is coming from, and get back to us here.
Seriously, unless you want to crack a head gasket, don't drive anywhere.
When you try to top off the coolant make sure it doesn't just pour out on the ground. If the radiator hosehas blown off of the thermostat housing any coolant you add will simply pour on the ground. Make sure this doesn't happen before you try to drive the car. Better to have it towed than to blow the engine.
ORIGINAL: Gunz80
well...I bought a coolant and refilled....then....it seems like I need to fix this leaking problem...I drove my underground grage,,...then..half of tank was gone....again...
Is it expensive to fix it? and how much?
I went to active green to check it....And they said radiator hose is the problem...There was a big hole....
man...This hose was big and attached radiator...It attached too tight (just like breather hose) that is why there was hole..
anyways, they told me that they have to order this part from jag..and it is only comes with completed part...it is $210.
damn....it is too expensive....
do you know where I can get this part in toronto???
jazzman20014
10-26-2015 04:15 PM
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
