Help auto gearbox intermittent problem
I have a 2010 auto x type occasionally if i drive it hard particuarly from a standstill my gearbox failure message pops up and it goes into limp home mode. Turning the ignition off clears the fault and no problems seems to exist with the kickdown as it usually is very smooth i was thinking i either need to top up the transmission fluid or its a sensor failure can anyone make any suggestions ?
I would start with finding a mechanic that can read the C codes and find out if any codes are stored. The standard code reader can't read the transmission codes. I would also recommend a good transmission service, oil and filter change.
Once you can get the codes read let us know what they are and we can go further from there.
Jaguar X-TYPE 2.0 - 2.2 Actuator (Turbo) - Part No: G-149 / 6NW008412
Jaguar 2.0 X Type Turbo Actuator Electronic G-221 728680
Jaguar X-Type Turbo Actuator Repairs | SINSPEED
JAGUAR X-TYPE 2.0 - 2.2 D ELECTRONIC TURBO ACTUATOR - Part No: 6NW008412 - ACS Power Steering Store
Also some have used this cleaner with good results =
http://www.innotecworld.com/products...aign=referrals
Jaguar X-Type Turbo Actuator Repairs SINSPEED
