Help with bench testing power window motor
Can anyone please help, I am after a wiring diagram for a power window unit so I can connect it in such a way that I can test a unit on the bench, ie: where does each wire connect, is it earth (ground) or live) do I connect a couple together etc etc. heeeeeeeeeeeeeeelp
Received 3,915 Likes
joseph1945, PM me your email addy and I will send you a complete wiring diagram for your car. Just tell me the year of your X-Type and I will send you the info you need. If it is a 2004, I also need to know the built month/year (written in the driver's door jam) unless you happen to know if you have the older or newer wiring setup.
Looking at the diagram for a 2002, here is a short break down of the wiring. Pins 2 and 7 require 12 VDC to be applied to them. Pin 8 is your ground. Pins 4 and 3 control the motor direction (4 is down, 3 is up). Pins 3 and 4 require a ground to be applied to them to make the motor move. Pin 1 is not used and Pin 6 is for the global close function (should need to ground this pin to make the motor go in the close direction, but the drawing is not clear on this).
Hafrod
05-07-2016 02:04 PM
