HELP! DSC Fault, and Now Engine light- New to the Jaguar World
I recently bought a 2005 Xtype 3.0 AWD. Love it...rides smooth, quiet, luxurious and has more that enough bells and whistles than I can keep up with.
Not too long after I bought it the DSC error came on. System Fault is what it says. It doesnt stay on all the time, just periodically.
I took it back to where I bought it and showed them the error msg. They had wondered if maybe the after market Auto start was causing the issue. I am going to take it back to them to take a look. I know that they disconnected the battery, and reconnected it. checked fuses etc.
Well today my engine light came on. I do not know much about cars, especially jags. The care still feels the same. I dont know what it could be. I need to get thoughts on what any of it could be. Could the auto start cause the problem with the DSC msg? Could the engine light tie in with any of the above?
Received 6,362 Likes
I had a DSC Fault Message. Turned out to be the battery. When you have your fault codes pulled at Advance Auto, have them check the battery. Mine registered 12.9 volts and only 225 CCA which is too low. The battery was replaced and my DSC Fault Message disappeared. If you need a battery use your cell phone or have someone order on line for you. I received a 25% off coupon & brought my out the door price to $125.
I only see a 20% off special code tonight. Well they change all the time. Good luck.
So took the car to Autozone today to scan for codes.
This is what I got:
P01010= Mass Air Flow (MAF) Circuit Range/Performance Problem
P1000
I also had them check the charge on my battery. He said it was a low charge and asked if I had any trouble with the car starting (i havent).
The engine light did go off for quite a while today while running errands, but it came back on again.
(I do know that they disconnected the battery the other day to see if it would reset the DSC fault msg im getting.)
The
This is what I got:
P1000
The
Attached is a picture of MAF - Mass Air Flow location. You'll need a philips screwdriver to remove it. You'll need to take the cover off that says Jaguar on it. This is where the air filter is located. Once you lift the cover off you can disconnect the plug, then use the screwdrive to remove the MAF sensor.
You have 2 options:
1 - Clean the MAF with CRC MAF sensor cleaner - $10
2 - Replace the sensor all together - $70 at O'Reilly's
Please leave a post as to what fixes your problem. This is helpful for other veiwers.
You have 2 options:
Backhertz (01-27-2013)
Great pic of the MAF. I just wanted to comment on the DSC Fault & battery issue. I had the same problem on Jan 4th. My battery in my opinion was fine as my car started up each & every time. I went to Advance Auto and they used a hand-held device which took about 15-20 seconds to test the battery & produce a tiny printout. The printout was the proof of the pudding. On my battery, it registered only 225 CCA & the next line said replace battery. I don't know if the Autozone had a battery, but Advance Auto did. They replaced the battery while I used my cellphone to order one over the Internet and take advantage of a battery promotion which took the $166 price down to only $125 and included free install. Removal/installation is very easy as these batteries have a plastic handle that pops up- no wonder they are so expensive !
So anyhow, while I was punching in the order, the Advance Auto person went ahead & changed the battery. I didn't get to observe. He comes back on in the store and about 2 minutes later, my order comes in. Bada bing, bada bang. I asked him if he would recheck the new battery just because I had never seen one of these testers used before. The new battery registered 700 or more CCA- I don't recall the exact figure. But it worked.
I got back in the car & turned it on as usual. The first thing I noted was the DSC Fault Message was gone & the red S light was out. My temperatures were in C instead of F, my radio presents were gone; however, my previous destinations were still present in the nav system. The other thing was my windows needed to be 'reprogrammed' by holding the buttons down or up- I tried both ways & it worked. So a simply touch on the window button results in the window going all the way down or all the way up again.
I am a retired radar engineer with years of experience in all kinds of electronics including EMI & RFI- interference and noise. I am very skeptical of using the disconnect battery method to clear the check engine light as there are tiny sparks which are seemingly harmless, but some sensitive electronics can be destroyed. I can not speak with any type of authority as to this practice on one of our cars. But rather, I suggest using a code reader/clearer to extinguish the CEL. Prior to my code reader arriving, I tried that and waited 30 seconds and noticed the tiny sparks & said , "Oh boy." When I got back in the car, the CEL was still on. Perhaps one of the other members who understands the system better than I can chime in here and explain.
Good luck to you.
Good luck to you.
Get a new battery first. These cars are ridiculously sensitive to low battery voltage and will throw spurious codes.
Re reconnecting the battery - Jaguar do take pains to suggest a clean (not 'dithery') reconnect.
The sparks are the module capacitors re-charging.
The reason to do a 'hard reset' is to discharge those capacitors which forces the modules to do a reload on power-on so, if there's some corruption in their little memories, it gets refreshed.
Funny you should post this issue. I had the same code, Cleaned the MAF sensor yesterday and the light cleared after several driving cycles. Feels like it is driving smoother. Am anxious to see if the fuel mileage increases at all.Was very easy to do. Get teh plug out, loosen a couple phillips screws, spray the sensor a few times without directing the spray right at the fine wires, reassemble and away you go.
By the way, I wonder why they sell the MAF cleaner in those huge spray cans. That's enough for 10 lifetimes unless you plan on cleaning it every couple months.
DCS fault
M : DTC P0101, P0102, P0103, P1104. MASS AIR FLOW SENSOR (MAF)
M1 : CHECK THE MAF SENSOR POWER SUPPLY
Yes Goto M5
No Goto M2
M2 : CHECK CONTINUITY OF THE MAF SENSOR GROUND CIRCUIT
Yes Goto M3
No REPAIR the circuit. For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
M3 : CHECK CONTINUITY OF THE MAF SENSOR GROUND CIRCUIT
Yes Goto M4
M4 : CHECK THE MAF SENSOR CIRCUIT FOR SHORT TO GROUND
Yes INSTALL a new MAF sensor. CLEAR DTCs. TEST the system for normal operation. If the DTC is repeated, INSTALL a new PCM. For additional information, Before replacing a PCM, contact Dealer technical support.
No REPAIR the short to ground. For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
M5 : CHECK FUSE 36 OF THE ENGINE COMPARTMENT FUSE BOX
Yes Goto M7
No Goto M6
M6 : CHECK FUSE 36 OF THE ENGINE COMPARTMENT FUSE BOX FOR A SHORT TO GROUND
Yes REPAIR short to ground between the engine compartment fuse box and the MAF sensor. For additional information, refer to wiring diagrams. CLEAR the DTC. TEST the system for normal operation.
No INSTALL a new fuse. Check the circuit for cause of fuse failure. CLEAR the DTC. TEST the system for normal operation.
M7 : CHECK THE POWER SUPPLY FROM FUSE 36 IN THE ENGINE COMPARTMENT FUSE BOX TO THE MAF SENSOR
Yes REPAIR the circuit from the engine compartment fuse box to the MAF sensor. For additional information, refer to wiring diagrams. CLEAR the DTC. TEST the system for normal operation.
No
- Turn the ignition switch to the OFF position.
- Disconnect the MAF sensor electrical connector EN6.
- Turn the ignition switch to the ON position.
- Measure the voltage between the MAF sensor electrical connector EN6 pin 1 (GU) and GROUND.
Yes Goto M5
No Goto M2
- Disconnect the PCM electrical connector EN16.
- Measure the resistance between the MAF sensor electrical connector EN6 pin 3 (GW) and the PCM electrical connector EN16 pin 44 (GW).
Yes Goto M3
- Measure the resistance between the MAF sensor electrical connector EN6 pin 2 (BW) and the PCM electrical connector EN16 pin 45 and pin 46 (BW).
Yes Goto M4
- Measure the resistance between the MAF sensor electrical connector EN6 pin 3 (GW) and GROUND.
- Check the fuse.
Yes Goto M7
No Goto M6
- Measure the resistance between electrical connector JB34 pin 93 of the engine compartment fuse box and GROUND.
- Measure the voltage between the engine compartment fuse box electrical connector JB34 pin 93 and GROUND.
No
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
NinoGrimace
08-26-2015 05:15 AM
