HELP!, Interior lights will not turn off
yep got the lock so well lubed you can hardly hear it click shut...! The replacement lock was faulty too so I just bridged the connection wires for the time being, Ill keep a look out for another one as Im going round. Next job is to sort the front interior lights, suspect a faulty circuit but will check the wiring first...
Received 3,910 Likes
Hi ya mate, hope you are well. Its the interior front overhead courtesy lights that were staying on, I have a feeling its a faulty circuit board than a short but will have to check both to make sure. Just been to lazy to fix it, been like that over a year now but I just unplugged them and used the centre light. Having the car resprayed in the next month then painting the alloys black, seen a nice XK in same colour and it look good. Will save the lights for when it rains so I dont have to get wet checking the cables etc.. lol
Silly 2 cents once accidently I had just programmed my garage door opener, then the next day forgot which button i used. I pressed the wrong button unknowingly started the programming sequence again which turns the interior lights on until the programming sequence in finished. I drove to work with the interior on then had to disconnect the battery because I didnt know if the light would go off. Once home I started the garage door opener sequence again and the interior light went off opener works great.
