HELP Jaguar X-Type 2.5 v6
Hi guys im new to jaguar ive always wanted one ever since i was a young lad they are gorgeous cars ive now finally got one but it is riddle with faults and driving me crazy i dont no what to do with it now i have 8 codes coming up p0300. p0304.p0305.p1314.p1313.p0333. p1646 and p1000 i would be very great full if any one could give me any advice as to what is wrong with my jag as i just want her back to her former glory.
Welcome to the forum aaron1579,
I've moved your question from UK & Eire Region to X-Type forum. this is the place to post tech questions about your X-Type and members here with the same model will be able to help.
Received 3,901 Likes
aaron, from what you are descibing, you more than likely either have old spark plugs in the car and the need to be changed or you are getting some oil in the plug wells which is leading to a misfire. either way, getting the intake manifold off to look at things is going to be first on the list. because you are getting this far into the engine, i would advise that you plan on changing the plugs and also replacing the upper manifold gaskets. as you pull the plugs, you should get a good idea of what is happening.
must you replace the upper manifold gaskets? no. but, as these cars get older, this is being done to prevent future issues relating to vacuum leaks. besides, the gaskets are cheap and pulling the intake off takes a little bit of time and if you are in that far, might as well get it all aet up for the long haul.
if you need some help getting the intake off, let us know. there are a few write ups on how to remove the intake. lan about three hours to pull the intake, replace plugs, and then get it all back together. after you do it the first time, the follow on times will be in the two hour range.
Thermo thanks so much for your advice i had the intake manifold off to check plugs they look really old and 2 of the front 3 plugs where covered in oil ive cleaned them up put them back in rebuilt every thing back up cleared faults started car took it a drive now just has 3 faults which are p1647 p0333 and p1000 . I think i will use your advice and replace plugs and upper manifold gaskets see uf that makes a difference .
aaron: Autolite Double Platinum APP605's sell for $4-$5 each including S&H on eBay:
Autolite Double Platinum Spark Plug APP605 | eBay
Autolite Double Platinum APP605 Spark Plug Set of 4 $Ave Here L K WOW F S | eBay
For the Intake gaskets, I used Fel-Pro MS 96485 for the lower gaskets and Fel-Pro MS 96494 for the upper gaskets.
Fuel Injection Plenum Gasket Set Felpro MS 96494 Loc 148 H15 | eBay
Fuel Injection Plenum Gasket Set Felpro 02 06 Jaguar x Type 3 0L MS 96494 LOC124 | eBay
New Intake Gasket Set Fits 01 06 Ford Jaguar 3 0L V6 Duratec CU 181 183 | eBay
Engine Intake Manifold Gasket Set DNJ IG4110 | eBay
I had an error code for a bad coil causing misfire. I pulled the intake and while it was off I made sure to do the spark plugs and change the one bad coil. Not a hard job, just take your time and don't drop anything into the motor. Now I did have a moment that frustrated me after the job was done. Within the week I had a new code, it was for the knock sensor.... That's under the intake. It's up to you but they do go bad and if you have the intake off I would do that too as the sensor is a cheap part.
Hi guys i have a problem i have replaced the all 6 spark plugs and both top and bottom lamda sensors and my car still isnt running right engine management light is still flashing im still getting codes 1647 and 0333 and some times i get 6 other codes 1314 1313 0304 0303 0305 0302ive also noticed that when i drove car then parked it up to check it my catalytic convertor was glowing red could this be the problem? I am coming close to getting rid of her .
aaron: I fear the catalytic converter may be damaged. Hopefully someone has a more optimistic outlook. The indicators are: (1) a glowing red converter, and (2) a flashing CEL warning of exhaust conditions that can or already have damaged the converter.
Some folks revive damaged converters. Others replace them. Here's a few threads on both options. Again, I hope other's respond with a better prognosis.
https://www.jaguarforums.com/forum/x...nverter-64693/
https://www.jaguarforums.com/forum/x...placing-33007/
https://www.jaguarforums.com/forum/x...estions-90385/
https://www.jaguarforums.com/forum/x...and-r-i-66236/
https://www.jaguarforums.com/forum/x...24/#post451742
Larry-Cleveland
09-25-2015 08:42 AM
