Help, my X-type has an ABS Fault. Afraid *********** will rip me
Guest
Posts: n/a
So its been 2 weeks I been enjoying my X-Type. I just got back from a *********** about my xenon problem, and they tried to rip me off charging me $900 and a $300 Diag Fee which I didnt pay, now I got another problem. I was driving home from work, and my ABS Light came on, it said ABS Fault. I have a Select Package on my car, but Im afraid that they will try to rip me off again, even though Im going to a different dealer. I called some dealers in Chicago and asked them would it be covered and all I get is it depends. I also asked what about Diags, they say it depends on if its covered under warranty. So Im under the impression that they will find a way to rip me off either way it goes. Can I go to Autozone, and get a code then call them and find show them the code and see if they will cover it or not. I dont want to get sticked with some rediculous fees. Its like Select is no good bc they will find a way to charge you some money when they advertise $0 Deductibles on Autotrader. Please help.
As far as I am concerned you little thief your car can go up in flames for all I care. Some technician that has nothing to do with what is charged at the dealer of by select edition may not have been able to feed his kid this week because you skipped on your bill and it was taken out of his paycheck.
I'm sure they're going to pull some BS if you tell them you got your codes read. Probably will relate something back like "we need to verify them ourselves." Plus, I'm not familiar w/Jag, but sometimes you can get a manufacturer's code (my Ford contour had 3 of them--failing cat!), which cannot be read by your OBD-II code scanners.
My advice is to get it read for free. DO NOT CLEAR the codes. Write them down, dig them up here and get some research ground. After determining what is wrong and what is covered, apply leverage to the dealership. Codes don't change, so if it is covered, I'm sure they will deduct the cost of diagnosis.
I'd wait till someone chimes in with experience on this issue, as I have not gone through this. However, I can't see anything wrong with getting the codes read and digging up the culprit yourself. Good luck!
ORIGINAL: FactoryJaguarTech
Guest
Posts: n/a
With my Xenon problems they charged me $300 diag for 15mins, then say $900 to fix sensors, motors. So they tried to rip me off at Howland Chicgo Jag. So Im going to another dealer. Anyways can I clear the codes so I can get the warning off ? What about disconect the battery and reconnect it ? I have a feeling that the next dealer will find a way to rip me off with fees tellin me its not covered. Select is no help it seems. Why warranty these cars CPO and you still will be shelling out money. $0 Deductible they advertise is BS.
Ancient your second part was correct. He went to dealer, got diagnosis and skipped out on the bill. He grabbed his keys wen service writer went to get manager and drove off. That is theft of services. I have no problem with people getting codes. Read my other posts, I help as many people as I can for free because I enjoy doing so.
$300.00 for 15 minutes of diag I think is BS, if I got charged that I would have called the police. lol.
I just think it is not right for him to have done that. If he had stuck around to have spoken to the service manager like an adult, it probably would have been resolved. Good luck going to another dealer btw. The jag community is very small. You think you will be able to go to another dealer in your area? As soon as your VIN is plugged in you will probably get a visit from the cops and arrested for theft of services.
Just as a side note, just about everything to do with ABS is covered under select as are HID lights for the motors breaking regardless of what someone here says. Only way a motor issue would not be covered is if they were broken as a result of an accident.
Guest
Posts: n/a
Theft of services, more like theft of my money $300 for 15 mins is crazy. Im afraid that the next dealer will try to hustle me on the ABS Fault, and say its not covered and tell me it would be $2000 to fix. Im only 18 and I dont have money to be spending on my new car which is suppose to be CPO Select Pack with $0 Deductible.
ORIGINAL: jagxtypeboy
Just a side note - if you are 18 do you have non factory wheels on your car? If you ridin on 22"s, thats probably why your ABS light is on and is also probably why your HID's broke trying to level out the lamps so far that they broke. Again, probably why Select wouldnt cover it.
Guest
Posts: n/a
I only have the factory X-Type Sport Wheels my car came with. $300 for 15mins of diag is just plain outright theivery. I seen a tech hook up a computer to my car while I was outside watching them wash cars. I didnt have $300 to give the guy to hook up a computer. I told my advisor I have select, then he comes back and sticks me with a $300 bill 15 mins later. Why are you worried about that ? The issue at hand is my ABS light is on and I dont want to get ripped off again at the next dealership. I go to college and I have bills and books etc. How can I clear this code, or get rid of this code without getting ripped off ? Can I disconect the battery ?
If you would read the posts, I told you that almost all ABS problems are covered by Select. Wheel speed sensors, ABS module, Brake switch, brake booster, Sensor ring all of it. Take it to the dealer. What does it matter? If they try to charge you, your just going to do a runner again anyway.
Guest
Posts: n/a
I can talk you through the ABS issue if you are willing to be mature, and do some work. You are a young and a little quick to react. trouble shooting takes logic and patience. drive sensibly with the light on until we get to the bottom of it. first step is to get the codes read and post them, you can try to erase the code, but please write down the codes before you reset them.
what is your level of technical competance? do you have a floor (trolley) jack? and a jackstand? can you get a wheel off etc..?
2.) $300 is asinine amount, no one is disputing that.
3.) I just finished college, and I drove a Ford Contour (still am driving). I don't buy the I'm on a tight budget, but own a Jaguar bit. (All you *******s are filthy stinking rich!! Well, except Jim, now that he's got a Mondeo!! [8D])
4.) If you want to just clear the code(s), yes you can clear it with a scanner or reset the PCM a la battery. It's a quick fix, and if it is a recurring problem, it'll probably pop back up in no time.
Guest
Posts: n/a
Well I only purchased my 04 X-Type Sport, I purchased it with 45K Miles, and Jaguar Select Package for only $11000. You must remember these cars are cheap. Cheap luxury car on a budget.So I can go to autozone and have them clear the codes right ?
2.) I'm not sure I understand why you're clearing codes. What are you trying to achieve here? I mean, it just seems like you are expecting these codes to vanish. That's not going to happen.
Running on a light isn't going to kill the car. Worse it can do is run on lean mode.
Guest
Posts: n/a
I guess I got a good deal. But anyways I want to know if I clear the codes does the lights go off ? Will this affect my car ? Im under the impresion people always do this to avoid high repair bills. At least thats what my friend does with his BMW M3.
No it doesn't avoid bills, it makes them larger.
Poor M3.
