help, need instruction how to remove cover to reveal jaguar stock radio!!
Guest
Posts: n/a
Good afternoon guys,
Let me introduce myself first off, i am new here. My friend has a jaguar x type 2002 v6 3.0. I need some instructions how to remove the front cover or whatever is holding stock radio so i can see if he's connections are good. All his 4 speakers went bad all sudden and he's tweeters are only working ontop.
Perhaps a manual you guys might have or common knowledge since you guys are jaguar users.
thanks a lot,
Deltasoft-----PS: if i post in wrong forum, please foward me to right one.
thanks again.
thanks a lot,
thanks again.
Remmove the very top plastic that covers the hazard button, it should just pop out with light force. There are 2 screws there, then remove the ash tray by removing the shifter face plate first, then the 2 screws for the ash tray will be exposed. When the ash try is removed, you will see 2 more screws for the bottom part of the radio.
Hope this helps
________
BeautyDuo
Hope this helps
________
BeautyDuo
yea, its just like Racer sed, but for the last two screws at the bottom, they are covered by a plastic piece so so cant see them, just yank it off to see the screws. i took mine out, i have an 04, but i think its the same. good luck with it.
Guest
Posts: n/a
wow thanks a lot , i printed it out and gave it to my friend , it did help!!!! you guys are the best, now one more question. The audio went out completly in all 4 spkrs but tweeters play audio. I am thinking it might be a fuse within radio? because it cant be possible all 4 spkrs be gone no sound, dont you think? or perhaps radio is defective on the 4 channels?
thanks please advise me on what you think best i should do. I have no warranty to repair this issue. So i must do so myself for my friend :-)
thanks guys,
Deltasoft.
thanks guys,
Deltasoft.
Sounds like your amp is singing the blues, but I would check the connections first, (one amp in the right rear pass door)
________
Creampie videos
________
Creampie videos
Guest
Posts: n/a
hey thanks alot man, i did checked the radio and connections are fine. now the question is :
where is the amp or amps in the car?
Does the radio has a built in amp?
How do i remove the door panels? is there any hidden door screws i should be aware off? because is not coming out.
Also do you have the wiring chart for the X type's radio in order for me to troubleshoot the cable connections properly?
thanks , let me know guys, very important,
Deltasoft.
Deltasoft.
Life iss too short my man, it's been about 2 weeks now and your still messing with that radio. Take it in the shop for repairs.
________
DEPAKOTE WITHDRAW
________
DEPAKOTE WITHDRAW
Jaguar Forums Editor
Jaguar Press release
08-27-2015 03:18 AM
