help with p1260 antitheft 02 xtype
Guest
Posts: n/a
hi.
my jag wont start. nothing happens when I turn the key. gives p1260 security input engine disabled code. is there any way i can reset the code without taking it to the dealer. i think what happened is the battery in the key died and when i tried to start the car with it the car didnt recognize the key and went into antitheft mode or something. i replaced the battery in the key but now it still is giving the p1260 code and wont let me start the car. its the v6 engine of that matters. any help would be greatly appreciated.
Received 2,191 Likes
Thats the battery for the remote, there is no battery for the key. It has a microchip, try your other keys. If thats your only 1, your screwed, try disconnecting the battery again but only the negative cable, touch the negative to the positive still connected cable. This drains all capacitors on the car and resets the ecus. They sometimes lockup just like your pc and do stupid stuff like this. This resets the ecu just like unplugging the you pc from the wall, and no it wont damage anything we do it all the time and this is called a hard reboot. If this doesnt do it, call a tow truck and take it to the dealer
LAjag (12-16-2017)
JagLove86
09-15-2015 07:05 PM
