Help please
Help please
I have a 2.2 diesel X Type estate. 2009
This problem has happened three times before but has suddenly rectified itself whilst being tested on the diagnostic so the fault was never found. The diagnostic computer showed no faults. The fuel rail pressure is normal in the few seconds it fires up.
The problem is that the car drives fine but then all of a sudden for no reason when you stop and then try to start the engine it bursts into life as normal but immediately dies after 1 or 2 seconds.
In the last couple of months I have put in a new battery, put in a bosch fuel filter, changed the MAF, changed the Camshaft sensor, cleaned out the EGR (which wasn't dirty), the fuel cut off has not triggered, but now it will start every time but will then immediately die after a couple of seconds.
So until I can find out why it bursts into life then immediately dies Im not going anywhere.
Any suggestions anyone ?
Ideally you would need to see live data of all the sensors.
Crankshaft sensor is a possibility as these are known to do this type of fault, also swarf can collect on this sensor too.
Another possibility in the pump inlet metering valve.
Also check carefully the wiring/connectors of the common rail pressure sensor.
Paul.
Paul.
Hi Paul, thanks for the advice, I have ordered a crankshaft sensor so I will put that in and see if it helps. Last time this fault occurred a friend (mechanic) connected his diagnostic computer and tested everything one by one and in the couple of seconds when the engine burst into life no faults were found. Then all of a sudden it burst into life and ran as normal for a couple of weeks until it happened again. Ill check the wiring too.
Well that was all a waste of time !
The new Crankshaft sensor made no difference.
She fires up, runs for about 2 or 3 seconds then dies. Over and over.
So heres a list of stuff I have tried:
sealed windscreen to stop water dripping on ECU cables
Removed ECU to check for water damage - none
New Varta Silver Dynamic Battery, 800Ah cranks at about 11v
Remove and clean EGR (wasn't dirty)
Remove fuel tank cap to check for debris or blocked intake (none)
New Bosch fuel filter, (cut open old one which had no debris)
New MAF
New Cam sensor
New Crank sensor.
Every step has made no difference whatsoever. She fires up first time then dies after a couple of seconds.
The engine warning light goes off as she fires up.
Any ideas anyone ???
Feeling a bit glum here.
New MAF
New Cam sensor
New Crank sensor.
So now she fires up and ticks over fine,
but on a test drive starts misfiring around 2000 revs and then cuts out. Fires up fine again and then cuts out about 2000 revs, when stationary she revs fine up to 2000 revs then misfires and cuts out, and now the engine warning lights is on.
Any thoughts Please ?
Harryxtype, the problem was in the air intake system, did you replace the air fiter, it's seem like some thing blocked the air in take; either the butter fly in the throttle body was tuck, or air leak in air intake hoses after MAF sensor, check those hose clams to see if they are fited and tight.
The 2.2d does not have any butterfly valve in the intake, it has no restriction.
If you were to now read the error codes, you will see insufficient egr flow, which is expected and will bring on the eml, it is the other error codes that will be of interest.
Have you carefully checked connectors and wiring that you have moved/changed before ?
It sounds like a possible weak sensor output, the crank sensor is the touchy one regarding position height, whilst I have not changed one yet, I believe the bracket/clamp allows limited height movement to be set on the bolt ?
I seem to remember the manual saying about checking that the sensor does not contact the flywheel.
Reading the codes would be a smart move now, one down one to go !
Paul.
Paul.
