Help - Remove and Replace headlight washer cover nozzle
Guest
Posts: n/a
The cover on the passenger side of my wifes x-type (2002) fell off at the car wash. They payed for a new one but it also included the entire nozzle (white in color). I cannot figure out how to remove the old one so i can insert the new one. Any help would be greatly appreciated. My honey do list will get bigggggg if i do not get this done soon.
Thanks for the help. I did search the forums but found nothing.
Here's what I did, real easy... Pull the old nozzle out(all the way out) with your fingers and HOLD! Snap just the cover plate onto it and slowly reset it into place... I didnt replace the innner nozzle and have not had any problems. The cover plate is the real issue, the nozzle should last forever...
Guest
Posts: n/a
yes the design is changed and for the better. I would not take the new one apart.
to get the nozzle out, you need to pull the old one forward and then use a small screwdriver to lift the clip that holds it in. I think it is more than obvious how it works> I did mine and did not think twice about it. the only hard part was to hold the thing forward without damaging the plastic on the bumper.
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
