Help with some codes
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/900x2000/screenshot_20201211_191959_3aa8f4c80500bb43739dc7237b5569f1adf96d52.jpg)
Hello all. I'm new here. Just bought the car a few weeks ago and I'm loving it!
I have had a few issues. When I got it, it was misfiring on 1,3 and 5. I have since fixed that by replacing coil packs and spark plugs, and also did valve cover gaskets while I was in there. I also replaced all vacuum lines and the check valve. So that issue was fixed. Now my new issue is that I'm getting these codes (see attached). The car runs and drive perfectly unless I let it sit at idle too long (like in a drive through) then when I take off it won't go above 3000rpm. It usually only lasts through 1st and 2nd gear then it clears itself up. Any suggestions from you professionals?
Thanks in advance!
