Help, still not running
Hi All
have traced my problems to (99% sure) a faulty transponder ring.
The car at the moment is at the mechanic for some testing
He has a new transponder tester and has checked 3 keys that read 134mhz, and cannot find a signal from the transponder ring on the ignition barrell
He will test further and let me know monday, looking forward to it
My question is then that all three keys tested st 134mhz and as an australian car most references say that it should be 433mhz as the UK cars and they are good
He didnt get a reading from the transponder ring but as its a new thing for him he needs to check it before finallf diagnosing it
There are some after market key suppliers that make a distinction and only supply key blanks and remotes for every other x type except 2003
My question is what frequency should a 2003 x type in Ausralia have in its transponder? the vin is SAJAG53N42YD09292 if that helps
I would just hate to change the T ring with the wrong one
Also when changing the ring do I need to reset any computer settings and the like?
Any info would be gratefully accepted
Regards
John
Regards
John
I suppose I should have clarified "immobilizer" = that does not ONLY refer to the trip one in the footwell. There are other "immobilizer" components in the car. That's again why I asked "did you follow the PATS diagnostic flow chart?".
https://www.jaguarforums.com/forum/x...stralia-57906/
Anti-Theft —PATS The passive anti-theft system (PATS) contains the following components: theft indicatorencoded ignition keytransceiver moduleinstrument clusterpowertrain control module (PCM)standard corporate protocol (SCP) communication networkThe PATS uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user. This system is known as SecuriLock® in North America, Safeguard® in the U.K. and PATS in continental Europe. This information can be found in owners literature. The PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code, with over 72 million billion combinations. Each encoded ignition key must be programmed into the vehicle's instrument cluster (the instrument cluster is also known as a hybrid electronic cluster [HEC]), before it can be used to start the engine. There are special diagnostic procedures outlined in the workshop manual that must be carried out if new encoded ignition keys are to be installed. The transceiver module communicates with the encoded ignition key. This module is located behind the steering column shroud and contains an antenna connected to a small electronics module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends the data to the instrument cluster. The control functions are contained in the instrument cluster. This module carries out all of the PATS functions such as receiving the identification code from the encoded ignition key and controlling engine enable. The instrument cluster initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START. The PATS uses the PCM to enable or disable the engine. The instrument cluster communicates with the PCM over the SCP network in order to enable engine operation. The instrument cluster and the PCM use sophisticated messages in order to prevent a theft. The instrument cluster and the PCM share security data (when first installed together) that makes them a matched pair. After this security data sharing, these modules will not function in other vehicles. The shared PCM ID is remembered even if the battery is disconnected. The instrument cluster also stores the vehicle's key identification code even if the battery is disconnected. There are special diagnostic procedures outlined in this workshop manual that may be carried out if either a new instrument cluster or PCM needs to be installed. All elements of PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start. PATS uses a visual theft indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS problem, this indicator will either flash rapidly or glow steadily (for more than three seconds) when the ignition switch is turned to RUN or START. PATS also "blips" the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
orangeblossom
04-27-2016 01:39 AM
unionjack
01-14-2011 09:21 PM
