Help with Troubleshooting AC Problem
The Car: 2003 Jaguar X-Type 2.5L Automatic Trans. with 84,000 miles.
The Issue: I'm sweating my butt off in this 90 degree weather because my AC doesn't work!
The rest of the climate control system works flawlessly. When I turn it to AC, it blows room-temperature air out of the vents. If I put it on Max Cold, it blows out somewhat warm air. If I put the fan setting on a low setting, it gets somewhat cool, but not enough to cool the car down. I'm thinking that because of the touchy fan setting issue and how the temp reacts, the refrigerant is low and most likely leaking.
I was considering buying a can of refrigerant and recharging it, then looking for leaks... but before I waste the cash on it I figured that I would ask here to see if I am even on the right path. Can someone possible offer me some advice as to how to trouble shootthis problem? Also,if I am onthe right track, can someone please tell me the location of the low pressure valve to recharge the system? Thank you so much for your help!!!
Steve
Steve
RE: Help with Troubleshooting AC Problem
I don't know how to tell... I'm not very experienced in air conditioning systems. When I put the temp to cool or low, it acts as if it should be blowing out cold air. The fan goes to the correct setting, but the air coming out isn't cold. To tell if the compressor is going on and off, should I physically look at the compressor in the engine bay? How do I tell if it is going on and off? Common sense tells me that the pulley would be turning all the time.
Just so that I'm understanding what I should be looking for... The pulley would be turned by the belt at all times. The clutch moves to make contact with the pulley so that it goes from free spinning when the AC is off to driving the compressor when the AC is on.... right? So I'm supposed to be looking for something that moves and makes contact with the pulley when the AC is turned on? Or does the pulley itselfactually move?
So, if the compressor activates and stays running when the AC is turned on, then it would need a recharge, right? And if the compressor doesn't engage when the AC is turned on, or if it engages and then disengages right away,then I would need a new compressor? Are these the onlytwo possible troubles, or are there other possible issues?
Thanks for the help!
ORIGINAL: sbxt
Not a problem..I owe you because when I went to take that picture, I discovered that one of the coolant return lines to the Coolant resevoir had almost cracked off the tank top..So I juryrigged it to get me to the dealer to have the tank replaced..otherwise I would have never noticed it until I was low on coolant..
