Help in the UK with tc refill
Hi hope people can help
i am in the uk and wish to complete Bojangles way of drain and refill of transfer box
Where do you buy parts required in the uk (west Midlands / Shropshire)
as i went to local plumbers and they looked at me like i was from a another planet
also what oil do everyone suggest and where in the uk can i order it
i have looked at demon-tweeks website but could not work out which oil to order
any help would be helpfull
Received 3,905 Likes
If you don't mind spending a few bucks, I can get the pieces together for you and then mail them to you. The parts are pretty generic. While Wild Bill's kit is very nice, but there are other ways of doing it too. I spent like $10 (5 euro?) on the 2 pieces that you need and then another $5 (3 euro?) on the clear tubing. The tubing can be bought at any hardware store. Worst case, I will toss in the tubing too.
Let me know if you are interested. I could probably have the parts to you in about a week (however long it takes to have the mail system go across the Atlantic). As for the fluid, I went with Mobil 1 75W-140 fluid as I recall. It ran me like $15 (8 euro?) a quart. Not cheap, but when 1 bottle is enough to do 2 transfer case refills, it goes a long way. Unfortunately, I wouldn't be able to send you the fluid through the mail.
Hi,
i've just changed the fluid in my TC...here's a write up:
http://www.x-type.org.uk/phpBB2/view...=2075&start=45
Funnily enough i'm in the west mids too (near solihull though) but the parts are easy to acquire - I got mine from B&Q - only cost a few quid (£ over here thermo - not euro!
) They all fit together nicely - apart from on the female connector where the drain plug goes, you need to grind some metal away with a dremel or similar. It's no biggie - you'll see what I mean when you get the parts.
You'll need the 1/2inch / 15mm parts by the way.
Oil wise thermo is right you need 75w140 - get it from here:
http://www.opieoils.co.uk/p-736-cast...lubricant.aspx
Hope this helps!
Gareth
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Hope this helps!
Gareth
Received 9,010 Likes
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
