HID Headlight replacement - Need to remove bumper cover?
Simple question from a still newbie. (Yes, I've read all the headlight posts - but I don't think this one was answered - maybe I missed it.)
Thanks for all of the good threads pointing me to reputable sites for HID D2S bulbs.
Do I need to remove the headlight assembly to put the new bulbs in? If yes - I need to remove the front bumper cover - right?
Thanks,
Dan
Thanks,
Dan
![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
Received 3,898 Likes
Dan, this is what I will tell you and you can take this for what it is worth.
Must you remove the headlight assembly to replace the bulb. NO!!!! BUT!!!!!!! (you saw this coming didn't you?). The internals of the headlights (especially as the cars get older) are brittle and the headlight bulb is not the easiest thing to get at. So, it can be possible that if you leave the headlight assembly in place, you may stress the internals enough to break them.
If you do remove the headlight assemblies, then yes, you have to remove the bumper cover to assess things.
WisconsinDan (12-13-2014)
Bulbs can be changed without removing the light but space is tight and you'll be working blind as you can't see and have your hand in there at the same time. Smaller hands help. If you need to remove the light unit you'll have to remove the bumper.
Here's the workshop manual pages for
Headlight Removal http://www.mjtemple.webspace.virginm...ht_removal.pdf
and
Bumper Removal http://www.mjtemple.webspace.virginm...er_removal.pdf
and
Just finished My HID upgrade today and it was so much easier to remove the Bumper and the Lights ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
polished the lenses while they were out also.
Plus with the lights out you can mount the ballasts nice and easy right behind the lights. Drivers side has a convenient hole already for you to attach the brackets. Passenger side has a nicely located hose clamp bracket you can use the bolt for![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
used the Kit from HIDextra.com had to change the spade crimps to get the wire through the provided boot but mostly plug n play
rudelover2
09-11-2015 08:53 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
