HID's Installed now Engine Light on -Help
Received 2,193 Likes
Just so you know alleyez the hids actually use less power than your normal halogen. Like I said take it to your local autozone and bring the codes back and we can tell you what each value means and Brutal can help you out more specifically with what the code says. The electrical system (from what I viewed with mine) is very weird sometimes and just disconnecting the battery can do funny things.
Guest
Posts: n/a
No fuses blown. Disconnected the battery then connected the HID's then reconnected the battery and they fired right up. Been using them for 2 days now, work fine ,but can't figure out the CEL. Disconnected the neg terminal last night for about 15 min to see if that would shut the light off but no go. I will try and get to autozone sometime this week.
BrentGardner
28
04-26-2024 03:08 AM
rudelover2
09-11-2015 08:53 PM
