High beam lights
High beam lights
Happy new year to everyone.
Basically my xtype turns on the high beam lights about 10-15 seconds after I lock the car with my fob. They stay on until I put my key in the ignition. I can operate them manually with no problems. This concern just started today about 3 hours ago.
Here's the long version:
I came home from work, shut the car off, got out hit the lock twice, horn and parking lights flashed and About 10 seconds passed and the high beams turned on. Went to pull the stalk and nothing changed. Put the key in the ignition and they turned off. Operated them with KOER and KOEO. Seem to work fine. Got out, locked twice again, had the usual beep with the light flash no further issues.
About 2 hours went by, got an item from the car, locked...beep...parking lights. 10 seconds later high beams turned on again. Put the key in the ignition and they shut off.
Sorry for the long write up, I'm a tech so I try to get as many details out of people as I can.
Thank you in advance.
rsa760041
23
09-25-2015 02:33 PM
KarimPA
09-12-2015 09:15 AM
rachelstr
09-03-2015 01:59 PM
