High beams won't turn off
Received 6,310 Likes
Welcome to the forum Rhino, don't forget to post your intro in the new members section.
Do you mean that you cannot switch between main and dip beams or that you cannot switch the lights off at all?
Correct. My problem is that my high beams won't turn off when I try to switch them to low beams. I researched this but the problems I've seen is that some people have a problem that the high beams won't come on when they try to switch from low beams to high beams. My issue is just the opposite. My high beams stay on all the time when I try to switch them off. .?!&@$. Maybe it is the switch. I disassembled the column and found the turn signal-high beam switch is a module, that may need replacing. Looks like an expensive module seeing that it is all connected to the actual turn signal, trip reset, and high/low beam unit. Any ideas or comments?
Received 3,892 Likes
Rhino, before you go replacing more expensive parts, humor me on something. Get into the fuse box inside the passenger compartment. Now, if you look, you will see a component labeled R15 (upper left corner). Pull that out. Now located component labeled R17 (just below R15). Pull that out and then put it into the R15 spot. Now, attempt your headlights again. Did the high beams go out? If yes, your problem is the relay is stuck on and you need a new relay.
If the high beams are still on, then remove the relay in the R15 spot. Now, using a multimeter, probe between pins 1 and 2 and see if you are getting 12 VDC. If no, then you have a crossed wire somewhere in the car. If you are getting 12 VDC, unplug the plug for the multifunction stalk. If the lights do not go off, then you have a problem with your GEM module or the wiring between the GEM module and the multifunction stalk. IF the high beams went out at this point, then you have a bad multifunction stalk.
Hope this helps.
Hope this helps.
Mr Twitch (11-30-2022)
Rhino (03-11-2013)
Thanks "Thermo", Hopefully it is an aftermarket part and I can find one online somewhere. If it is a dealer only part, it sounds expensive. Is the GEM module on the steering column too. When I took the hood off of the steering column I thought I saw a self contained unit that housed the turn signal and all? Hmmmm...gonna have to do some research. I don't have a service repair manual and have done all maintanance by research online or just by my own knowledge. If you know where I may be able to access this or these parts, I would appreciate the info.
Rhino, follow this link https://www.jaguarforums.com/forum/x...archive-66034/ and you can download JTIS which will give you all the info you need.
Rhino (03-13-2013)
Hope this helps.
Hope this helps.
Yesterday, I did a tranny flush on my son’s ‘03 x-type. I had to remove the battery and box to access the fill plug. When I was done and put everything back, I noticed that both the high and low beams were both on and they wouldn’t switch off. I read all the replies here regarding this and was about to try the suggestions, but then I decided to look in the manual. Under “headlights”, it mentions turning your ignition key to the number II position and flash them. I did this both with the lights in the off position and then in the on position. I turned the key to the off position then back on, tested the lights and voila, they were back to normal!
Wolfy
05-28-2024 08:06 AM
rsa760041
23
09-25-2015 01:33 PM
