High Pitched Frequency sound at 30mph?
This just started happening. But today its not there. Been going on for about 2 weeks. From 29-31mph there is a loud high frequency pitched whistling/whine sound coming. I have an appointment at the dealer tonight but I'm not sure if they will hear it since I'm not hearing it now. It is there in 2nd, 3rd, and 4th gear so it is not effected by engine rpm.
Any idea what it could be?
It is a 2003 X-Type 2.5 w/ 52,000 miles. Auto tranny.
Sound does not come in park or neutral. Sometimes it comes when driving after I just started it and continues. Other times I drive around for about 5 min till the sound comes. But it usually shows up pretty often. It is a real annoying high frequency sound. Kind've like when ur tv is on but set to a different input so the screen is black. You can kind of here a frequency so u can tell its on even though it may look off.
I hope it doesn't have to do with my transmission. I used to use the J-Gate a lot and I redline a decent amount since its a slow car.
My dad took it to work the other day when we swapped cars and both him and my mom heard the sound. So it definitely isn't just me hearing something small.
I'm part of a BMW forum so I posted on their and people think it might be the Rear Diff. But I've had the car since new and its never made a sound. Just these last 2 weeks its been doing it. Then yesterday temperatures hit record 64*F (crazy chicago weather...was 20* 2 days before...), and when I dropped my sister back at her dorm I didn't hear the sound.
I just hope the dealer heres it. If they say that they couldn't reproduce the sound, then I'm gonna be having to drop my car off everytime I hear it and hope they here it too.
Guest
Posts: n/a
i have a similar issue on my mom's car, my mechanic (not a jag tech) insists it's the rear brakes.
he fixes it and it's fine for a month but then the sound comes back.
my sound is very intermittant, some days it does it all the time, then a week could pass with no sound at all, it's rather mystifying.
If it is the rear Diff and that's quite possible...This is another example of why I think it's stupid to have so-called permanent lubes..
On my Land Rover it was the same thing on it's rear Differential (it had the same kind of drivetrain AWDas the Jag X, right down to the JATCO tranny)..Anways, I took the diff cover off and drained the black goop out and refilled it with some Castrol SyntheticGear lube and the noise went away.
ORIGINAL: aloiseau10
I have the same problem on my 02' X-Type. It's almost a loud whistling noise. It's really frustrating at times. At took it to a body and shop and they did some work on my brakes but the sound is still there.
I had a similar noise, and when my fiance was driving it, it started to shake violently, then there was a loud clunk. Transfer case was the culprit.
Same with my car but when I go about 25-40mph it starts making likea train on mine. I took it to a dealer but he said it might be a wheel bearing. Also when I go on highway speed 65+ it starts making this the same sound but I think a little louder. The tech says that is normal for all jag x-types.
Sounds are easy to trace if you know how. Sounds to me like the center bearing on the driveshaft. But without being there hard to say. Diff noise would change when you turn left to right. Trans also would change with rpm. Drive shaft noise will remain pretty constant.
ORIGINAL: jasonzimbran
The sound mostly comes up when I'm just coasting and sometimes when I'm decellerating. I don't know whether to call it a "whistling" or "whirling" sound, but my car doesn't shake violently. I mostly get the sound when it's cold out too, but I have gotten it on some warm days.
ORIGINAL: FactoryJaguarTech
Then, on Christmas Eve, the t/case went CLUNK! When turning left/right, the car never showed any symptoms that the t/case was on its way out. But under acceleration, it'd howl like a dog in heat.
Got the transfer case changed, and the noise went away. So if you have that noise, I'd say you'll need a transfer case.
Same here. Except I hear it while accelerating slowly or decelerating/coasting where the speed comes to 30mph. The transfer case sounds like an expensive part to replace... Is it? Also the sound does not change when turning. If I set cruise control at 30mph, I feel like blowing up my car or shooting myself in my head before going even 1 mile because this frequency is just sooooo annoying. Feels like my ear drum is gonna explode. Hard to describe. It has gotten louder recently. It was tolerable when it first started and I just thought it might have something to do w/ 20 degree weather and 50k mile car. But it was there when it was 30's outside and 40's. Stopped now in the 50's.
I cancelled the appointment at the dealer tonight. If it comes back when the cold weather gets here again in a few days, then I will take it back in.
Bowyota (09-05-2013)
