High Pitched Frequency sound at 30mph?
ORIGINAL: Master Deep
Same here. Except I hear it while accelerating slowly or decelerating/coasting where the speed comes to 30mph. The transfer case sounds like an expensive part to replace... Is it? Also the sound does not change when turning. If I set cruise control at 30mph, I feel like blowing up my car or shooting myself in my head before going even 1 mile because this frequency is just sooooo annoying. Feels like my ear drum is gonna explode. Hard to describe. It has gotten louder recently. It was tolerable when it first started and I just thought it might have something to do w/ 20 degree weather and 50k mile car. But it was there when it was 30's outside and 40's. Stopped now in the 50's.
I cancelled the appointment at the dealer tonight. If it comes back when the cold weather gets here again in a few days, then I will take it back in.
Brand new, it's 1500? I think...
I hate to be the bearer of bad news, but if it's the same noise I think it is, then it's only a matter of time before it takes a **** on you. Mine went out on Christmas Eve, and I couldn't have been more pissed about it. But, that's life. Get the clutch done, have it back for a week only to have the t-case go clunk. Ain't life great?
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
ORIGINAL: Dennis
]..I'm gonna change my transfercase lube oil this weekend for sure now...
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
Anyway, it's runnin like a champ now.
So how does the transfer case go bad? Is it something about me doing something bad while driving? I tend to redline a lot once the car is warmed up and it has never given me problems. Change oil every 5000 miles. I did try drifting a few weeks ago in a snowstorm in an open parking lot. The sound started after that.
I never tried to do any drift/donuts in the dry or wet (even though its almost impossible in the dry) cause I know its really bad for the AWD system and I don't wanna mess up my differentials. Trying in snow may be bad too but it's a little better. I just wanted to get to know how the car slides w/ the new tires so if it happens on a road i know what to do.
Made me a believer
#28
yeah I was about to ask that same question. Is it something you do that makes it wrong? Well my dealer told me it costs $450 for a wheel bearing to be replaced. When I go on the 65mph on the highway and I dont accelerate it sound like a train anyone have this problem?
Can't say I have this problem. The wheel bearing is expensive to change. Most of them are pressed in and are a pain in the ****! They are terrible to change! Sure does make a difference though...I'll post videos of it very soon bug me for them so I can show you the difference. I took 2 vids with my camera phone in my escape before and after and on the way to the shop to do it I only was doing like 45-55 and on the way home where its almost quiet I was doing like 70-80! PM me in a few days if I don't post em...450 does seem steep though jason...thought you had a warranty on yours? Here's a link for a rear hub/bearing assembly which should make it easier (haven't looked how the jags hub and all of that works) to do the repair. Bearings in my escape were pressed in and I couldn't get the hub and all...A good shop should be able to tell you which wheel bearing is bad and possibly only change one wheel bearing...LINK
You could hit up jag_genius or ken for parts but I've found the dealer gives the same price on parts just not a very cheap labor rate!
#31
#32
#33
Any clue why the whine comes only at 30mph?
And if I change the fluid now will that help at all? How much would the dealer charge to change the fluid? An oil change cost me $50 there.
Not all is lost. I drove with the noise for 2.5 months with the noise before it went out. And that was on a bad clutch...
#34
#37
Received 9,010 Likes
. ![Name: T15ESSJAG5.jpg
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194574d1501334378-high-pitched-frequency-sound-30mph-t15essjag5.jpg)
![Name: X6JYMSAAB5.jpg
Size: 6.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194575d1501334378-high-pitched-frequency-sound-30mph-x6jymsaab5.jpg)
![Name: AudiX6JYM-2.jpg
Size: 6.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194576d1501334378-high-pitched-frequency-sound-30mph-audix6jym-2.jpg)
Hey master deep...........I had similar issues about a year back. They come n go, usually worse when cold for some reason?
Took it to the dealer as I thought it was the tranny and paid £103 for them to check it out
The result?
Your car is in tip top shape sir and everythings normal[&:]
Sometimes its there and sometimes its not....go figure
Why not ask the help of our resident Jag Tech in the Technical section?
Good luck
Jim
The result?
Good luck
Jim
#39
OMFG I'm scared.
So the high pitched whistling is still there at 30mph. It gets louder and softer randomly. Sometimes it doesn't even occur. But it tends to happen most of the time now.
BUT, a new sound developed the last snow we had on Wednesday. When moving from a stop and driving slow so that everything is quiet, I hear a Mechanical Whirring sound. Sounds like turning a bunch of gears in your hand without enough lubrication. Or standing on a treadmill, and moving the belt with your feet manually, without turning the power on. I always hear this now since Wednesday. Sound does fluctuate a little bit with speed. But I hear it mainly at parking lot speeds while accelerating, cruising, and braking since there isn't any road/wind noise at low speeds. It's like i'm forcing something to turn as I drive that doesn't want to turn.
This sound has me feeling sick. Since I think it might be in the drivetrain. And something to do with the transfer case (which is known to fail). Called up my friend since he blew out the viscous on his talon 6x so far. So that maybe he can diagnose it before I take it to the dealer. He was telling me that if I hear a sound from the transfer case, I better just pull over ASAP. Since as soon as it goes, All 4 wheels lock up and i'm ****ed. I'm just gonna spin and can't brake or do anything. Happened to him before. So now i'm scared. Car drives fine still the last 2 days.
So anyone think they know what it could be? Thanks.
