Hockey puck for jacking up xtype?
Old 02-19-2016, 05:22 PM
RobinGa's Avatar
Default Hockey puck for jacking up xtype?
I have seen suggestions other places to use a hockey puck with a cutout to cradle the jacking point underneath the unibody and cushion the floor Jack. Has anyone tried this on an xtype? I see where people use wood blocks but I'm thinking the hockey puck might be a good option. Thoughts?
Old 02-19-2016, 05:39 PM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
I'd use wood or some other more suitable item. The puck might suddenly split.
Or jack somewhere that doesn't need a puck/etc.
Old 02-19-2016, 05:48 PM
RobinGa's Avatar
That's what I was actually concerned with using wood
Old 02-20-2016, 03:23 AM
JagV8's Avatar
Don't put any grain the wood may have (some don't, such as plywood) parallel to the thing that would split it (go for 90 degrees). You can't do the equivalent with non-wood.
Personally I like to find a hefty bit of metal on the car and then at most you could crush the wood a little. Can't fail suddenly.
(Of course use axle (jack) stands as well.)
Old 02-20-2016, 09:43 AM
DPK's Avatar
DPK
DPK is offline
Going with what JagV8 just said I think,,
I had some of these jack blocks still left over from when I had my X, that I made out of a 2x4..The arrows indicated the wood grain direction..the notch I cut for the frame rail, is perpendicular to the grain...They worked great.
JagV8 (02-21-2016)
Old 02-20-2016, 04:24 PM
RobinGa's Avatar
Looks good dpk
Old 02-21-2016, 10:58 AM
JagV8's Avatar
Looks great.
Old 02-22-2016, 07:12 AM
RobinGa's Avatar
I took the advice here and made some wood blocks which worked well. Thanks
fireman-175
02-29-2016 09:05 PM
XJsc-guy
02-28-2016 09:38 AM
tablesawjock
General Tech Help
02-18-2016 01:22 AM
Qgregg
02-17-2016 08:56 PM
Hafrod
02-15-2016 01:53 PM
Quick Reply: Hockey puck for jacking up xtype?
