Home link retrofit?
Short answer, yes. I did it about two years ago, it's model year independent, so it'll work with your car. All you need is a copy of the schematics and you'll be good to go. It's very easy.
This should help you out: http://snk.to/f-chnl69j1
The only missing wire that you'll need to run is for the Dimmer-*‐Controlled Light. The power source for the non HomeLink is from the battery, so it's on all the time. You'll need to run one from the any dimmer-controlled device up to the roof (cigarette lighter, headlight switch, etc). The power draw is very small so it won't trip a fuse or anything.
Did you get the pigtail (aka original connector) with the new console? If yes, then jut follow the chart I gave you. If you don't have the pigtail, it's going to be hard.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
RaceDiagnostics
09-13-2015 02:22 AM
