Horns not working
As the relay clicks, the clockspring, GEM, etc should be fine. As you haven't found the horns you won't have checked their earth/ground. The ground point is the outboard one of the two under the lefthand headlight assembly. The horns are under the battery box.
The relay might click, but also check that when it does, 12 v is getting through the relay to Fuse F38, 20A in the Main Distribution fuse box - the one under the hood.
Pastorrice (05-28-2014)
Pastorrice (05-29-2014)
philwarner
09-05-2015 10:05 AM
